Televison & Video Logo
Daniel Morales Roca Posted on Mar 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zenith dtt901 not getting signal, no RF output to tv
Hi, I was given a Zenith DT901 converter, and it does power on and everything, but doesn't get any channels, not the antenna, also doesn't output through RF, tv out! only by composite cables can I see it work! could the tuner be bad? did a channe; scan and nothing! seems to me the tuner is dead or something!
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Mar 14, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715257
Points
48227
Either the tuner is dead or something in the box menu is set to composite out only.
Might be the reason it was given away?
Can I use my zenith TV tuner converter box model number dtt901 to watch my phone on TV
The Zenith DTT901 receives OTA (over-the-air) digital signals from TV stations and converts them to an analog signal to be used with an older analog television.
So the answer is no.
How do I program a Toshiba remote to a zenith converter box
Signal converter boxes are pretty easy to set up - ABC News
abcnews.go.com/Technology/AheadoftheCurve/story?id=5485537
Digital Switch: How to Set Up Your Converter Box. ... If you subscribe to cable, satellite or some other pay-TV service, you'll continue to receive programming. ... aToshiba TV in my kitchen: Magnavox's TB100MW9 and Zenith's DTT901. The boxes are simple enough to set up, though I prefer the Zenith's remote control and ...
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!
Zenith remote control code list - channel recovery morning ...
www.thompsontv.com/zcodes.html
Where can I download a schematic for a Zenith dtt901 converter
Try the manufacturer's website and/or do a Google search using
" Zenith dtt901 manual pdf
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Zenith TV has no place for yellow, red, white composite plugs
This TV doesn't have an AV input, so there are no input jacks other than the antenna connector. If you want to connect a device that has only AV outputs (your red, white and yellow plug) you will need an RF converter. This will take the AV signals and convert them to a channel 3 or 4 signal you can tune in on the set.
But since you don't seem interested in spending any money, you'll probably not like to hear that the converter runs around $15 most places. Take heart, there is an alternative. Find a VCR (if you don't have one already) that has an RF output. Many of the the newer DVD/VCR combos only have AV outputs. You're looking for one that has an "out to TV" threaded connector on the back. These units already have an RF converter built in. Connect your AV plugs to the line in jacks on the VCR and switch to that input, and you can use your video game or DVD player through the VCR.
1helpful
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Hooking up a dvd player
as you say that it is old tv so there is a possibility that there may not be audio video socket where dcd player can be connected. OR You will have to purchase one video RF converter.RF converter contains one video input in yellow color & two audio input in red & white colour & one cable connector as output. Connect the dvd output to this converter & tune tv program in which place you receive dvd signal.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
