SOURCE: ricoh aficio 1515 all-in-one: problem with scanner
get your manual owner, and do the following instruction there
SOURCE: ricoh aficio 2022 error code sc542
I have a Aficio 551/700 and the display reads SC124 anyone have a suggestion on how to re-set this
Thanks
ES...ASD
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
SOURCE: My Ricoh Laser Printer is not working
Check all network cables conecting to the machine. Then rebbot the machine. Make sure that the machine is "online" by pushing the [printer] button and then the online offline button which is located directly under the [printer] button. It looks like an arrow pointing to the right. By pushing this button you will see on the screen ready or offline.
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
