Bosch Axxis WFL 2060 Front Load Washer - "Bosch maxx wfo 2050" issues I have a problem with this machine as I set the program and then press start button the machine takes water in to drum for required level. Till here every things seems allright but then (as expected) drum should start cycling but never start cyling at all. Just stay as is.During this time it seems that machines program works electronicly however doesn't cycle the drum at all. After some time machine start dumping water out automaticly once again (as assumed that the cloths has been washed but in fact cloths are not washed at all). and then continues electronic action as taking water again but physically no action on drum in antire washing process. Some one out there please can help me with this problem. What could be the problem with this machine right this time? If you have any idea what might be the problem just let me know. I do really appreciate your assistance in this matter.
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
