Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
Monitor automatically clicks into power saving mode
I have a flatiron monitor that is attached to my laptop. It was working fine; after I was away for two weeks, monitor starts into windows but then immediately goes into power saving mode and image defaults to my laptop screen.
  • 10 more comments
  • wilzyk Nov 26, 2007
    when i turn on my computer it seems to turn on but my monitor immetiately clicks into powersaving mode and doesnt respond to the mouse or keyboard rendering it useless..can you help me???
  • Niconette Feb 29, 2008
    I bought 2 Flatron L1919S LG monitors. One for work and one for home. The one at work works 100%. When connecting the one at home it says "Power Save Mode"?? How do I get this of?
  • jiberoo Mar 05, 2008
    Yeah the same happend to me
  • TLR4670 Mar 07, 2008
    working on computer and the monitor shuts off into energy saving mode for no apparent reason. Lose everything and start over again Flatron L1710S
  • Anonymous Mar 11, 2008
    I have an LG 206 wtq 19inch digital monitor, was working fine all month went away and returned, plugged it back in and will not get out of power save mode?
  • Anonymous May 13, 2008
    Monitor goes to power save mode
  • Jakkar May 13, 2008
    I'm having the same issue with an LG Fantasy, 19".
    Upon purchasing an Xbox 360 Elite and using the monitor as it's display with a HDMI/DVI converter and my 5.1 speakers as stereo, the monitor continued to work fine on the PC upon a cable swap - until running GTAIV. It no longer functions as a PC display, automatically shifting into standy upon reaching the desktop. The BIOS and XP loading screen -do- display.
    I can only assume that with these minimalistic LG products, beautiful as they are, some internal mode or setting is being altered by our actions, software or other hardware plugged into the monitor, and with the Fantasy for example, there is only ONE button on the body of the monitor, a touch sensitive power switch.
    These mode switches are impossible. I'll try safemode in a few moments and if that fails, I'll take the screen to a friend's house and test cables.
    My recommendation, having not yet tried more than simple, late night methods, is to plug the monitor into another computer, and if you get a display try to default the monitor's settings before plugging it back into the old computer, and trying another monitor on your old computer to reduce video settings until you isolate the issue.
    Good luck
  • Anonymous Aug 13, 2008
    Have a Flatiron (W2241T) that worked fine with an old Dell desktop. We had a power outage at home and when we started up the screen went automatically to power saving mode. Need some help.
  • feebeecakes Sep 12, 2008
    I plugged my LG 171OS into a MAC Ibook laptop thing. screen works when connected to MAC, but as soon I plug into PC hard drive its on power save...I have read through solutions posted here, but as it just flashes "power save" then turns off, and screen is black, I am struggling to work out how to reconfigure screen blind-I can't see anything on power save. I know nothing of motherboards nor do I dare open the hard drive...surely there's a simple Control ALT delete kind of combo that will wake the damned screen up??? I am typing this on the MAC laptop without using the LG screen.
  • Anonymous Feb 12, 2009
    after starting, my monitor displays "power saving mode".
  • ekrosen2 Feb 27, 2009
    lg flatron w2052tq clicks in power saving mode for no reason i returned monitor for vnew 1 still happenbs and all my power settings set to never turn off
  • cloud sawada Apr 24, 2013
    take out your video card and put the monitor cord (or what it's called) to the internal connected to the motherboard it works for me
I have an LG W2261V, and an old Sharp LL-T19D1-H. The PC runs both just fine, and the PSU has plenty of power. Unfortunately the LG handles power save mode very differently, where the LG would not switch on after entering this mode unless reset (unplugged, PC rebooted, etc). Extremely frustrating, as the old Sharp never had any problems exiting its own power save mode. The LG would enter this mode based on the monitor power settings (in whatever power scheme you are using) in the screensaver tab in display properties. I fixed this by selecting "Never" for "the Turn off monitor" property. I guess this is a warning to those who may wish to buy a new LG monitor, but want to use a power scheme to turn off the monitor.
Posted on Apr 22, 2009
I had the same problem on LG monitor too. the problem started when I accidentally bump my computer's desk. i can not see anything on my monitor because my monitor went automatically into power saving mode and i can not fix the problem with the keyboard or mouse because i don't have any PS2 on my CPU. WHen I try to open my CPU there will be this beep sound twice. So I try to check and reinstalled the memory and the VGA card and it miraculously make my computer active again. I hope my experience will be useful to the others.
Posted on Oct 09, 2008
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
It's an LCD so the problem is most likely the back-light inverter board. Take a flashlight and shine it directly into the screen from the front. Can you see the image on the screen now? If the image is there but you can't see it without the flashlight than the inverter board needs to be replaced. This is a VERY common problem. Good Luck and let me know what happens, His Dudeness
Posted on Jan 21, 2015
  • 176 Answers
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Posted on Oct 04, 2014
Excuse me but if you cant SEE anything on your monitor (because your pc is in power save mode) how on earth are you supposed to right-click to check the settings? scratching my head over this one.
Posted on Apr 08, 2008
  • mnjj Feb 14, 2011
    I agree.......I cannot get on the desktop, otherwise I would not need help...How do I get to the
    desktop if my screen is on power save mode....I have an LG monitor
    try removing your video card and put the monitor cord in the internal it works for me..
My samsung 19" Syncmaster 920NW monitor is connected to analog port in my hp pavilion laptop.After the windows xp logo and loading,the monitor screen goes blank and the power LED blinks.The display functions normally on booting up in VGA mode (640X480).It functions normally on safe mode (800X600).In the normal mode,the screen goes blank and the power LED flashes.But, the laptop,main LCD panel shows alright.The display adapter is Nvidia GEFOECS GS 7600.What could be the poblem.
Posted on Oct 06, 2007
    New Friend:
1. Battery in the mother board is dead.
2. Driver is bad.
3. Video Cable is bad
4. Video Card is bad
Posted on Jul 11, 2010
    Novelist:
  • 114 Answers
Check the display settings of your video card. This can be done by right clicking on the desktop and selecting properties. Then go to the settings button and clicking advanced. All video cards are different, but there should be a tab there that will allow you to configure how you want to monitor to be utilized (mirror of laptop screen or extenstion of laptop screen). Often times, laptops have a button to toggle between modes (Example, DEll is Fn F8).
Posted on Oct 02, 2006
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 254 Answers
SOURCE: Monitor automatically clicks into power saving mode
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Posted on Nov 28, 2007
Nov 28, 2007 | LG L1915S 19" LCD Monitor
I have a Dell Dimension e521 desktop that has gone into energy save mode after I ran Norton security check.. Pressing any key or clicking the mouse doesn't do anything. The screen is black and says...
you may find you have the screen resolution set to high, try changing to 1024x768 and try again. if this works it means your monitor ain't up to the job of your better machines.
Nov 15, 2013 | Cars & Trucks
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Samsung 931bw screen flashes on and off
unscrew the back cover of the monitor then remove to access the power supply board, look for a leak or blown up electrolytic capacitor. just replace with the same rating and value a panasonic brand of capacitor much better with low esr.
Jun 28, 2012 | Computers & Internet
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
I don't have video on my 400sd4 laptop
If the system is booting up completely and you can hear is starting up then the problem is limited to your video.
First try this
Boot up your system so that it's in windows (listen for start sounds and windows music etc)
once you believe the system is fully booted press and hold the FN key. While holding FN press and release the F3 key one time and then let go of FN. Wait a few second and see if the LCD screen comes on. If it does not try FN-F3 a couple more time, waiting a few second in between.
If that does not work then try plugging in and external monitor to verify that the system is working otherwise. If the external monitor does not come on right away then press Fn-F3 again with it attached to allow the system to send a signal to the external port.
If it works on the external monitor but cannot come on the LCD screen, the that indicates a problen inside your laptop or LCD screen.
Dec 03, 2009 | Gateway 400SD4 Notebook
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
31,817 people viewed this question
Top LG Computers & Internet Experts
Ekse
Troy Staley
Troy Staley
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
