I recently switched to time warner roadrunner and have received a new modem to go along with it. I hooked up my SMCWBR14-G2 router exactly the same way it was set up to my previous modem but it does not seem to be working. I can't figure out why. The router is working, since my iPhone can pick up the wi-fi but there's no internet.
SOURCE: For SMC7904WBRA :: How to use Cable Modem on ADSL router/modem
Looks like your device does not support playing router for cable internet. Would recommend you get an actual router, or alternately if you have a computer with two network adaptors you could plug one into cable modem, plug other in to LAN side of router, then configure turn Windows Internet Connection service, will need to disable the DHCP service on the router. I highly recommend you get a real cable/dsl router to do this tho. Linksys 54g series has been one of my favorites. Router homepage on SMC site. http://www.smc.com/index.cfm?event=viewProduct&localeCode=EN%5FUSA&cid=1&scid=4&pid=1588
SOURCE: Using Wireless + PPPoE at the same time kills router. SMCWBR14-G2
From your description, I am assuming you have a direct ethernet
connection from an RJ45 connection in a jack in the wall. If this is
the case, then you would just need to purchase a wireless router
(linksys, D-link, netgear, etc). Connect the ethernet connection from
the wall to the routers internet or WAN port. You will need to access
the routers firmware configuration and set it to connect with PPPoE, so
get your username and password from your ISP if you are not sure what
it is.
You will be able to continue to have the PC plugged into the router with
an ethernet cable, and then run the laptop with a wireless connection,
just be sure to configure the laptop with the security key if
applicable.
If you were using a software PPPoE connection on your PC, quit using
it. Just set your network adapters on both computers to DHCP, and you
should be good to go.
Hope this helps
Chris (ziraffa)
SOURCE: smc setup cannot be accessed but have network
login to your router and go to wifi and check for the mac address of your laptop, if its require to change anything do it according to it.
To know the mac address of your laptop go to command prompt and type --> getmac
SOURCE: I use Wireless router Model:
We have used gtalk with static ip number. Sounds more like the port it uses isn't open. It could be that they block the port at your office. When using static ip numbers the gateway must be the number of the router in order for it to get out to the internet.
SOURCE: Op de SMCWBR14-G2 sttat
Probeer:
Well, once reset you will need to login to the interface and resetup all
the connection information. You can do that from the WEB interface
just logon and reset. No special software (except a web browser) is
needed.
I think the SMC default address is http://192.168.2.1 just log on and set it up. Resetting just restores the factory defaults, it does not erase the system.
Rarely does a router need software on a computer. Even the linksys that
have a big sticker USE CD FIRST -- its only there for those who don't
understand routers!
There is a good help forum for SMC at
http://www.dslreports.com/faq/smc/3.1_Th...
