RCA L32HD31 32 in. LCD HDTV Logo
Posted on Nov 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hissing. My tv makes a hissing noise whenever it is on, my bigger tv makes a much quieter hissing noise. It is somewhat distracting. Anyway ideas what may be causing this? Thanks!
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Nov 04, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783303
Points
6681
If the hissing noise is from the LCD, it could be from the power supply due to failing capacitors. This noise is generated when the TV is trying to compensate for the lack of voltage/curent requirements.
2answers
Engine makes hissing noise. Valve cover or just a gasket?
Soounds like it to me.... But to be sure, knowing the make, model & year of the car would be a huge help!
Tire leak hissing sound heard under hood from engine
Not the tires
Only makes a noise with the key on
or engine on
No idea without the car
Hissing noise from under the hood- passenger side.
loose hose clamps hole in one of the vac lines it seems to only hiss when its under pressure
1helpful
26helpful
2answers
Air/Hissing Noise from Brake Pedal
this noise is caused by a defective power brake vacuum booster, (big round thing behind the master cylinder) the diaphragm is leaking vacuum.
Engine is making hissing sound.
That hissing could be a vaccuum system leak, have youe tried pinpointing the sound from under the hood?
Car hissing sound
The noise maybe the p/s pump fluid return,GM had some problem with this but nothing bad. GM makes a resticter that goes in the return line of the pump, it will slow the fluid down going back in the pump stopping the hissing sound.
21helpful
3answers
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Sylvania Fridge Problem
This may be the refrigerator itself making that hissing noise, which is not uncommon.
Please provide the make and model number for the unit.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
