I saw you helped others on this machine. any suggestions on:
Started out with E20. Now E23. I cleared clogs and now it sometimes rinses, sometimes spins, never drains and just shuts off after getting to these last cycles. I am handy and would like to take care of this myself. What do you recommend?
E23 - Drain pump relay on control board failed. Replace control board or wire.
The E20 error code indicates a problem with water drainage. Inspect the drainage hose for kinks that could impede the drainage flow. This frequently occurs when the machine is pushed up against the wall without allowing room for the hoses. If there are no kinks, the hose is probably clogged. Carefully detach the hose from the machine, and use a garden hose to force water through it. If the water doesn't pass through, use a plumber's snake to clear the clog. If there is no clog, inspect the drain pump for clogs. Unplug the machine, and open the small rectangular door towards the bottom of the front of the machine. Drain the pump through the emptying hose into a container until the water flow stops, and rotate the pump impeller to clear any foreign objects. Close the pump and restart the cycle. If the problem persists, contact a service center.
Bad pump. Only a year old! Luckily Frigidaire is buying me a new one. thanks
When I start my washer the control panel seams to work but when I start it it just starts to fill and then it switches to the no spin cycle and just shuts down
