I reviewed most questions here. Sounds like a sub-zero that has stopped making ice is probably suffering from a frozen solenoid.
This explains what happened two weeks ago - my son left the freezer partially open for quite a while and the freezer temp went up to 36 degrees. Voila, there was ice the next day or so.
Question is, how much would it cost to replace the defective part?
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
SOURCE: water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
SOURCE: Describe how to replace a solenoid valve on a subzero 532
easy.. disconect power . important. remove the kick plate. the water valve is locate in the left side. its a blue color. inside a bracket or attached whit 2 screws ( depend on the serial break) remove the water valve from bracket. disconect the plug and the and the line and thats all.............................................. NOTE. MAKE SURE TURN THR WATER SUPLY MOST LIKELY IS THE COOPER LINE . CLOSE FROM THE WATER METER OUSIDE YOUR HOUSE OR CLOSE TO THE WATER VALVE....... DO NOT TRY TO REMOVE THE FRIDGE.............. good luck... LEAVE YOR COMMENT IF IT WAS GOOD FOR YOU... THANKS
