Question about HP LaserJet 1320 Printer
No print on 3x5 paper with Linux?
I am trying to print on 3x5 inch paper (portrait) from LibreOffice 3.3.1 OOO330m19 (Build:8) tag libreoffice-3.3.1.2 (opensuse 11.4) with printer driver CUPS PS ppd hpijs3.11.1.19. I have adjusted the page size for the document and in the printer options. I insert the paper manually through the adjusted feeding **** over the main train. The paper is pulled into the printer ok but it stops without print inside the printer. Opening the back flap for shorter paper path does not help. I need to take out the cartridge and remove the sheet. Is there any manual entry on this - like which options are ok, which minimal margins, will it do duplex etc.
5 Suggested Answers
6ya staff
SOURCE:
Priya darshan
  • 3422 Answers
SOURCE: HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Posted on Jul 05, 2008
secretgeek50
Beth Muffley
  • 57 Answers
SOURCE: getting extra 1 inch margin on ''normal'' or ''best'' print
Hi - have you checked the settings for both the document(s) you are trying to print and the defaults for the printer? It could be that there is a default setting that is trying to override what you want to do. I can't think of a reason for it to act differently with different quality of print, unless the ink is running low - that can affect a document printing or not, but again, I would not think to this effect.
Some things to check on -
- Go to the control panel, open the Printers and Faxes folder, and right click on your printer.
Choose PROPERTIES. Make sure everything is set like you want it to be.
(If you are on a network of some kind, someone else's settings could be overriding yours. If you are not on a network, make sure "Do not share this printer" is checked on the sharing tab.)
-try to update the driver. Here is a good place to look -
http://preview.tinyurl.com/6bwuk8
I am assuming you have already actually checked for little scraplettes of paper that might be stuck near a sensor or an ink cartridge. I'd even pop the ink cartridges out and put them back in. Sometimes dust can build up on them if a printer isn't used often, or has been sitting for a long time.
Also, make sure you don't have a setting on your own computer to print out a blank sheet before a printing job. If your printer is actually run through an I/T department at work, they could have it set up by default to kick out a separator sheet to help keep orders separated.
I hope one of these things might work for you! : )
Posted on Nov 20, 2008
Anonymous
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
kashifali200
SOURCE: HP LaserJet 1020 test print without driver
Pull up the top cover and down it three times.
Posted on Aug 01, 2010
How do I stop my printer from skipping a blank row of labels in between each row I print?
I was using LibreOffice Writer to print terminal block labels on my TDP43MY and was having all kinds of problems. (I tried EasyMark too, but had just as many problems.) The printer was constantly switching landscape and portrait modes on me. It would print 2 sets of good labels (portrait) and then the next label would be landscape. It did this no matter if I printed one page at a time or if I printed the whole document. I spent over half a day trying to get it to work, and finally succeeded - read on.
No surprise that the Panduit TDP43MY printer is really a Zebra printer. I discovered this by accident when I first got the printer. I connected it without first installing the driver and windows asked for a driver for a Zebra printer. Knowing it was a Panduit, I rejected windows offer and installed the Panduit driver. I spent a whole day trying to get it to print correctly and decided I would try windows recommendation of a Zebra driver. I did some digging and discovered it is a Zebra TLP 3842 printer. I removed the Panduit driver and installed the Zebra TLP 3842 driver. The version I have says "Windows driver for ZDesigner TLP 3842 Version 5.1.07.6290 Copyright 2016". I then used LibreOffice Writer to print my labels again. Wonder of wonders it printed with ZERO problems! Yeah for Zebra!
May 06, 2014 | Panduit TDP43MY Thermal Label Printer
I have a bizhub 300C. When I print a pdf the top inch is faded
Mike does this happen with all prints? does it go away if you change the orientation of the paper. portrait to landscape? Happen when you copy ? Try different file type does that change?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
I have a canon mp 240 and it Prints fine if you only need half of the document. It cuts everything in half! Like it reads the header wrong or blows up the words or make extra spaces. How can I get it to...
I thought maybe you have the paper size set to Landscape rather than Portrait. If not, then you might look at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport
I did some searching on that site and it yielded the hlep below which may give you some help.
Issue: How do I set my printer so my printout fits the paper size I am using?
Solution: Use the recommended Print Area MP240
Printing Area title-bar.gif To ensure the best print quality, the machine allows a margin along each edge of media. The actual printable area will be the area inside these margins.
Recommended printing area (dark blue):
Canon recommends that you print within this area. (o_darkblue13.jpg)
Printable area (light blue):
The area where it is possible to print. (o_lightblue14.jpg)
However, printing in this area can affect the print quality or the paper feed precision.
o_area15.jpg i_note.gif Note
Borderless Printing
By selecting the Borderless Printing option, you can make prints with no margins.
bullet_s.gif When performing Borderless Printing, slight cropping may occur at the edges since the printed image is enlarged to fill the whole page.
bullet_s.gif For Borderless Printing, use the following paper.
- Glossy Photo Paper "Everyday Use" GP-501
- Photo Paper Glossy GP-502
- Photo Paper Plus Semi-Gloss SG-201
- Photo Paper Pro Platinum PT-101
- Photo Paper Plus Glossy II PP-201
-Photo Paper Pro II PR-201
- Matte Photo Paper MP-101
Performing Borderless Printing on any other type of paper may substantially reduce printing quality and/or result in printouts with altered color hues.
Borderless Printing on plain paper may result in printouts with reduced quality. Use them only for test printing. You can perform Borderless Printing on plain paper only when printing from your computer.
bullet_s.gif Depending on the type of paper, Borderless Printing may reduce the print quality at the top and bottom edges of the paper or cause these parts to become smudged.
See A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide.
See Letter, Legal.
See Envelopes.
sikaku.gif A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide
Size
Printable Area (width x height)
A5*
5.56 x 7.95 inches / 141.2 x 202.0 mm
A4
8.00 x 11.38 inches / 203.2 x 289.0 mm
B5*
6.90 x 9.80 inches / 175.2 x 249.0 mm
4" x 6" / 10 x 15 cm
3.73 x 5.69 inches / 94.8 x 144.4 mm
4" x 8" / 10 x 20 cm*
3.73 x 7.69 inches / 94.8 x 195.2 mm
5" x 7" / 13 x 18 cm*
4.73 x 6.69 inches / 120.2 x 169.8 mm
8" x 10" / 20 x 25 cm*
7.73 x 9.69 inches / 196.4 x 246.0 mm
Wide*
3.73 x 6.80 inches / 94.8 x 172.6 mm
* This page size can be used only when printing from your computer.
o_ap_069.jpg o_darkblue6.jpgRecommended printing area
o_lightblue7.jpgPrintable area
sikaku.gif Letter, Legal
Size
Letter
8.00 x 10.69 inches / 203.2 x 271.4 mm
Legal*
8.00 x 13.69 inches / 203.2 x 347.6 mm
o_ap_074.jpg o_darkblue4.jpgRecommended printing area
o_lightblue5.jpgPrintable area
sikaku.gif Envelopes
Size
European DL*
4.06 x 7.12 inches / 103.2 x 180.8 mm
US Comm. Env. #10*
3.86 x 7.96 inches / 98.0 x 202.1 mm
* Envelopes can be used only when printing from your computer.
o_darkblue8.jpgRecommended printing area
Jun 30, 2011 | Canon PIXMA MP240 All-In-One InkJet...
At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
You can usually find it in the FILE menus
Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Printing on 3x5 notecards.
Some printers have a slot in the exit tray to use for envelopes and cards, if yours does not it may not support printing of cards. Please provide the model number and/or check the HP website for information.
Dec 08, 2008 | Office Equipment & Supplies
Printing on a 3x5 card
sounds to me its software issue, the best way to do this is to go into your printer properties and check to see if it has selected 3x5 for print not 8 1/2 x 11
my wife has that problem all the time when shes trying to print pictures of the kids and ushally its due to not being setup on the printers properties you can also set it up from right here
if you go to file on the top menu here and then goto print from here we will be able to select the printer and goto the options on it and make sure the page is set for 3x5 make sure your printer is highlighted and then click on preferances and then look in there. I dont have a printer hooked upto my laptop right now so I cant give you any further steps but I know its in there.
let me know how you make out if I have to put a computer onto my laptop and give you more detail on this then I will
Oct 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
MFC-5440CN 4X6 PRINT
mabey try using windows, not linux, make sure you have driver and other software on CD.
Jul 21, 2007 | Brother MFC-5440CN All-In-One InkJet...
HP LaserJet 1320 Printer Logo
76 people viewed this question
Ekse
Thomas F. Schneider
