After it completes thewash cycle the hot water continues to drip into the tub
SOURCE: Washer
Suem...Check your lid switch. With the lid closed, push on the atuator with a small screw driver...see if it starts agitating. Revised switch kit part number is 12001908. Catriver..post back.
SOURCE: washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
SOURCE: Maytag Atlantis MAV6200AWW Washer Problem?
is your drain hose at the top of the washer .is the water just runing out is it being pump out
SOURCE: My Maytag Neptune washer continues filling with water e
Does it fill when the machine is powered down?
If it does then the fill valve is stuck open and needs replacing
If it does not then you need to check the pressure switch and the air bell on the outer drum which probably has a ball of jellyfied soap in it.
If you take the back off you will see a thin plastic or rubber hose going from the bottom of the drum to a small flying saucer type object.
If you pull the hose off the bottom connection and blow into it you should hear a clicking noise from the pressure switch.
If it clicks then clean out the air bell and refit the hose .
If it does not click then get a new pressure switch
A repairman would test it live but that is not recommended for untrained people
SOURCE: I just purchased a Maytag Centennial washer ..it
There may be a water level/pressure switch that will accommodate your washer. However, if you install it, I am certain that during the normal warranty period, if you need service, the manufacturer will probably void your warranty if they notice the alteration!
Contact an appliance service company.
