The battery won't charge when I put the charger in. the charge light keeps flashing saying please connect your charger then says charging.
If you are using your original charger and you noted that your battery is not charging, just to be sure you can take it to any qualified service center where someone with an electronic tester can erify the output of your charger/adapter. If it is OK, you may have a problem in the electricinput system of your tablet or the battery . Some tablets don't have user-servicable batteries so in this case you should need a repair service.
Keri
Maybe a bad charger.
Mark
Motorola Support
SOURCE: how do i connect my motorola xoom to my computer
you can download 3DP Chip v11.12 from Mediafire
Open
it,and you will found Your driver like Example on the
screenshoot,and Click it,you will Redirect to the Driver you've need.
Please don't forget to rate it if this helpfull.
SOURCE: why does my motorola xoom keep freezing
This is probably due to it running out of memory. Mine does the same. Try installing a task killer app and periodically kill all the background apps you are not using.
