Broken door handle. Need to replace if possible.
SOURCE: Frigidaire Upright freezer Baskey
remove the basket sliders frome each side and install a couple of nylon washers between the slide and the side of the freezer on each side it will narrow the distance and the nylon washers will not rust
SOURCE: frigidaire modle ffu21f5hwb door handle loose how
Pop out the screw hole covers and tighten the screws.
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
