Ovens Logo
nicholas weir Posted on Mar 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fisher and Paykel Paprika Oven Top Elements Full hot!!
Fisher and Paykel Oven, Oven elements work fine and warmer drawer. Unfortunately the 4 top elements all go on full hot when turned any one of them on low. They are either off or full hot? Is this a controller problem and where is the controller? as i can only see the switch to turn low to high for the element and this goes to the element itself? Any help?? cheers
Peter
Level 2:
Champion:
  • Fisher and P... Expert 203 Answers
  • Posted on Feb 08, 2017
 Peter
Level 2:
Champion:
Answers
203
Questions
0
Helped
97291
Points
471
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
3 Related Answers
blade11EME
  • 6 Answers
  • Posted on Sep 13, 2009
SOURCE: Hi my Fisher & Paykel Paprika stove (Model
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
goober123
  • 9 Answers
  • Posted on Dec 11, 2009
SOURCE: Thermador SC301T heating elements not working (top
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Anonymous
  • 31 Answers
  • Posted on Jun 22, 2010
SOURCE: My Fisher & Paykel Paprika oven has
check the ignitor and the oven thermost. the oven control board may be out.
Fisher & Paykel Thyme model. How do you remove these screw in type top elements please. Appreciate your help
To remove the screw-in type top elements of a Fisher & Paykel Thyme model, you will need to use a screwdriver. First, turn off the power to the appliance and unplug it from the wall. Then, use a screwdriver to unscrew the screws that are holding the elements in place. Once the screws are removed, the elements can be lifted out and replaced.
Hi the hot plates have stopped working on my fisher and paykel oven
there is a seperae fuse for the elements if it is wired as a two phase which mean at your fuse box there is teo oven fuses one of them is blown or tripped
I have an OR90 Dual fuel range oven. My problem is that the main oven the bottom does not heat up? The top is working fine
check both oven elements are working if ok check thermostat probe inside oven isnot close to or touching any of the elements if all os ok then replace thermostat
Oven heats up slow
check both elements are working
2answers
I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
6helpful
Hi my Fisher & Paykel Paprika stove (Model FPRA6102AW) Needs a New Oven element, and 3 of the plates stay on Hot. Are these parts available and how much would they cost please: x1 Oven Element x3 Switch...
Top Fisher and Paykel Ovens Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
David Spradling
David Spradling
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
