Codes are made up by the universal remote control manufacturers.
DVD player/TV manufacturers do not make codes for their products.
You will have to look in the instructions for your remote control to
find a code. If you cannot find one, you will have to try the listed
codes one at a time to see if any work. If that also fails, you will
have to contact the manufacturer of the universal remote. Try going to
their website. E-mail them if you have to.
Not all universal remotes will work with all devices. This is why universal remotes are not really universal.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Thank u!!
got it sorted now, it was on the remote.
