SOURCE: what kind of foot pedals(to stop/start) are used
A simple push to make release to break switch will do for the stop/start function like a roland dp2 damper switch ... Search google shopping for some decent prices or if your confident you could make your own from parts like a momentary footswitch or "non-latch" switch and some mono guitar cable and a mono audio plug and some boxing (I recommend this only if your confident with soldering and want to save a lot of money)
May I also add I have one of these drum machines at home and they are brilliant for getting the "Genesis" or what I like to call the "Phil collins" sound! But I never expected anyone to still be using one of those! Good luck in your musical persuits!
SOURCE: How can I put a walz beat in the Alesis
Page 59 Odd time signatures of the owners manual explains how to do this. Type Alesis SR16 manual into Google and you can download a copy from media.zzsounds.com Please rate this if it helps. You can also download documentation here:http://www.alesis.com/sr16 under DOCS and Downloads
SOURCE: I bought an Alesis SR-16 drum machine from an
click this link directly
Download the complete
user guide (490 Ko)
---- the link is of the user and trouble shooting manual.in that all the possibilities which can be done are mentioned.you can try all the possibilities one by one.
and yes you can transfer data from one sr-16 to another sr-16 .first you will have to tranfer the data from sr-16 to your pc.then connect the another sr-16 and transfer the data to the erased sr-16.
click the link and check out the possibilities.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
SOURCE: the tempo indicated on the alesis sr16 is inaccurate
how can i change the tempo on song compose, for example step 01 tempo 60 and step 02 tempo 120??
Thanks.
SOURCE: Alesis sr16: How do you hook it up??
Come from the main outputs, probably labeled L/mono and R and connect those to your mixer for your audio system on either stereo mix input OR two two inputs that are panned opposite.. DO NOT connect this to a consumer type stereo system as you may blow the speakers or amp. Consumer stuff just isn't able to take output from music equipment such as this UNLESS the volume is kept very low.
