Question about D-Link (DKVM4K) (dkvm-4k) 4-port KVM Switch
DKVM4K, no vga output
I own one D- Link, DKVM-4K KVM switch. It was working perfect for two years with 4 PCs on it until last week i switched from PC1 to PC3 and the screen faded out slowly to blank and the monitor messaged me "No signal". I thought that there might be the graphic card but when i tested PCs without the switch, everything was OK. I tested them again through the switch and only mouse and keyboard were working perfect, but no VGA signal. All Pcs working on the exact same resolution (1280x1024 at 75Hz). Can somebody please help me what might be wrong, or perhaps where should I apply for a repair?? The bad thing is that this happened 34 days after the warranty expired......
    Guru:
  • 42 Answers
I don't know anything about that KVM but you might see if there is a reset button to reboot it. or if it has an external power supply unplug it and try resetting it that way.
Posted on Apr 01, 2017
6ya staff
SOURCE:
Loteck
  • 233 Answers
SOURCE: mouse and keyboard not recognized on second computer
Sounds like KVM has a bug. Maybe their website has a fix.
Posted on Dec 21, 2008
Anonymous
SOURCE: Good morning - I'm using the
My problem was resolved by moving the keyboard\mouse to another port.
Posted on May 08, 2009
Anonymous
SOURCE: using KVM-121 with 2 monitors
You should be able to -- the KVM switch would just switch inputs for the monitor, but since your two monitors would be plugged in directly to your computers, the switch wouldn't actually be affecting your monitor inputs.
Just make sure to plug your monitors directly to your computers and not use the switch.
Posted on May 23, 2009
duane_wong
Duane Wong
  • 6826 Answers
SOURCE: I have a D-Link DKVM 4 Switch that I have been
A new model switch would probably work better with Windows 7 laptop. I have experienced some incompatibilities with older peripherals or accessories when upgrading to Windows 7.
Good luck on this repair.
Posted on Dec 26, 2010
richard
SOURCE: i just bought d-link kvm-221...
I got this problem also; the caplock indicator didn't even lit. The problem is current consumption. KVM switch, keyboard (250mA) and mouse (100mA) were draining too much current. I changed the keyboard for a 100mA and it worked.
I hope this can help other people...
Posted on Jan 04, 2012
How to connect 2 computers to a dlink 4 port kvm switch?
The unit comes with all the cables in order to connect up to four computers to one KVM switch. If you're only using two computers, then you'll only need to connect one computer to Computer 1, and the second computer to Computer 2. The KVM will recognize that only two devices are connected, and generally skip the inputs for computers 3 and 4 until they have a device connected.
Feb 26, 2011 | D-Link DKVM-4K (dldkvm4k4port) KVM Switch
How many computers does a dlink 4port kvm need to worl ?
Just 1 and you can add others later if u like.your ip is stored in the dlink .
Mar 01, 2010 | D-Link DKVM-4 4-port KVM Switch
Switch is locked
Username :D-Link
Password :D-Link
OR
Username :admin
Password :admin
Dec 05, 2008 | D-Link DKVM-16 16-port KVM Switch
Using KVM-121 with 2 monitors
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
Sep 07, 2008 | D-Link DKVM-2K 2-port KVM Switch
Problem connecting two PCs by DKVM-4K
You should always use 1 switch per pc as that's mostly recommended.
Apr 11, 2008 | D-Link DKVM-4K (dldkvm4k4port) KVM Switch
Hotkeys for D-Link DKVM-2
In my case, it is <Scroll Lock>, <Scroll Lock>, <1> or <2>
And NOT F1 or F2 as the previous writer suggests.
Good Luck,
Ludvik.
Jan 03, 2008 | D-Link DKVM-2 2 PORT KVM KEYBOARD VIDEO...
Keyboard and mouse problem!
I've had this problem happen lots of times before. usually restarting the PC with the switch enabled to the PC that is booting will solve this problem. For some reason, sometimes the drivers don't load for the mouse and keyboard when starting up the PC.
Dec 16, 2006 | D-Link (DKVM4K) (dkvm-4k) 4-port KVM...
D-Link (DKVM4K) (dkvm-4k) 4-port KVM Switch Logo
103 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
