SOURCE: filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
SOURCE: Kenmore Dispenser Locks
You will be very glad to know I have an answer to your problem. I am guessing that your refrigerator was manufactured in 2002 between about March and November. This part does not really matter but I am giving you this as a history lesson. If I am correct Your model # starts with 253. and that means it was manufactured by Frigidaire for Sears. There was a glitch in the board that is in the panel you replaced that causes the problem you have described. You need to replace the board in the touch panel and your problem is gone. You will need to have the model number in order to order the part. The part will be available through Sears or other appliance parts dealers.
supertechks
Please don't forget to rate me
SOURCE: Water filter indicator light
On my samsung I needed to press the ice timer and ice mode together for 3 seconds.
SOURCE: I replaced my HV Control Board on my maytag
First did you program the board correctly and second make sure all the connections to the board you replaced are in correctly.
SOURCE: My maytag MSD2556ae side by side refrigerator water/ice dispenser
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
