Hi viper_xp, I have a HP psc 1210 all-in-one unit that doesn't feed. I read your 'spring tention' solution, but I can't access the spring through the back panel with my hand. I can reach for it with a screw driver or a sharp object.. Did you open the unit entirely?.. Do we have the exact same model?.. Could you be any more specific? pics? anything!
SOURCE: driver for hp psc 1210
if yo have internet connection pls download the driver from this link http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/HP/Hp-psc-1210-allinone-210.shtml or go to any nearest cyber cafe and download it bye
SOURCE: HP 6940 will not print
Turn the printer off
Open the back door and
gently turn the paper roller upward until it clicks. Make sure the door is securely closed. Wait a few more minutes then turn the print back on. I hope this helps.
SOURCE: PSC 1210
Here is the link to download the needed software from the HP website, You just need to selecte your operating system and follow the prompts to download and install:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90764&lc=en&cc=au&dlc=en〈=en&cc=au
Cheers
Emmanuel
hello!!!
here you can download
the printer driver of your
HP PSC 1210 All-In-One InkJet Printer
click here
SOURCE: flashing lights on hp psc 1210
After i posted the comment for you, I found thru HP's website a list of the lights flashing and what it means depending on the pattern:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00007641
