Vivitar MAGNACAM Binocular Logo
Posted on Mar 18, 2012
Need driver for linux - Vivitar MAGNACAM Binocular
Sound doesn't work under linux
We'd need to know what computer you're using to be able to help here, Linux sometimes needs specific drivers (and sometimes has no available driver at all) for devices to function.
The best bet is to look up what sound device your using, like a sound card, or what motherboard your computer has, and do a google search for that device and "linux driver".
You should find what you're looking for, if it exists, when you do that.
Does this need a Linux Driver?
you will need a linux driver to use. should be easily available if not bundled within your linux build. what have some operating limits for the printer depending on the drivers obtained. hope this helps
1helpful
Linux drivers of maxxonet laptop
usually you don't need linux drivers
after installing linux you must type
yum install
and it will search for all software and drivers for your laptop
Need Linux Drivers
Sorry to break it up to you but I tried looking for a driver for linux for the motorola wu830g but was unsuccessful but you could try ndiswrapper it didn't work for me though but I was using Ubuntu good luck =)
3helpful
2answers
I need linux drivers for OKI C5100n
Some Oki LED printers do have Linux drivers available. You should contact Okidata here:
my.okidata.com
or
1-800-OKI-DATA (1-800-654-3282)
1helpful
2answers
WiFi driver for Acer Laptop 4720 for Linux (Fedora version 8) free download
Try this link and see if it helps you locate the driver you need for linux. These are the Broadcom drivers, http://zh-tw.broadcom.com/support/ethernet_nic/netlink.php
1helpful
4answers
Wi-Fi drivers for Acer Aspire 4710Z for linux
The drivers for Windows can be used if no specific Linux drivers exist. There's a program within Linux called NDisWrapper which is designed to use the drivers provided for Windows XP in Linux. Refer to your particular distribution of Linux for the details on how to set up NDisWrapper from within your distribution (I've only done it in Ubuntu so have no experience of other distros)
2answers
X5470 with Linux
First: Shouldn't you have addressed you comments to Lexmark?
This is a site where questions are answered by people from all over the world - I doubt that there is anyone answering questions here who works for Lexmark.
Note: I totally agree with you on the fact that manufacturers should produce Linux drivers - but here's the rub - there are so many versions of Linux that a manufacturer would need to write so many versions of a driver that it would be uneconomical. It would be much easier if there were fewer versions of Linux (at least only a few core versions - say Debian and RedHat only) rather than every version of Linux requiring it's own software and drivers etc.
And yes it would be good for Manufacturers to release the code to anyone who asked for it - but where is the Commercial Security in that?
I like Linux - but I think it is about 10 years away from being a mature and user friendly Operating system. The primary need for Linux programmers is to start using Standards when developing their OS. Think of this problem as an analogy - It wouldn't matter what size or design wheel was created if it used the same axle bearings and hub as everyone else. It could still be put on the cart and used.
Just my 2 cents worth.
Nvidia Quadro4 (128MB RAM) driver required for linux 2.4.20.18.7
hi there..
here is the link for your Quadro 4 Graphics for linux 32 Bit
To download and install the drivers, follow the steps below:
STEP 1: Review the NVIDIA Software License.
You will need to accept this license prior to downloading any files.
STEP 2: Download the Driver File
Download - NVIDIA-Linux-x86-96.43.05-pkg1.run
SuSE users: please read the SuSE NVIDIA Installer HOWTO before downloading the driver.
STEP 3: Install
Type "sh NVIDIA-Linux-x86-96.43.05-pkg1.run" to install the driver. NVIDIA now provides a utility to assist you with configuration of your X config file. Please see Chapter 3 of the README or run 'man nvidia-xconfig' for details on usage. Instructions for those wishing to edit their X config file by hand can also be found in the README.
__________________________________
here is the link for your Quadro 4 Graphics for linux 64 Bit
Download - NVIDIA-Linux-x86_64-1.0-9639-pkg2.run
STEP 3: Install
Type "sh NVIDIA-Linux-x86_64-1.0-9639-pkg2.run" to install the driver, then edit your X config file as appropriate. If you are using a Linux 2.6 based system, type "modprobe -q agpgart", first. See the text README for more detailed instructions.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
4answers
How can i installed driver of sata hdd for linux red hat
if you are installing red hat 8 and higher there is no need to install extra driver because linux is the only operating system which will install everything including drivers, office suite,programming tools etc .... as far as my suggestion dnt install old versions of linux instead install new version ... there are many linux available
ex: fedora core 4,5,6 ,knoppix live cd linux ( which boots linux from cd no need install it) ,ubuntu,red hat,mandrake,suse ....
you can download it from net 4 free as linux is open source 4 all ...
be careful while installing linux especially during partitioning..... if u make a mistake you will lose all datas
Top Vivitar Optics Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Vivitar Optic Expert? Answer questions, earn points and help others
