When I enter a DVD that is not Blu-Ray, the DVD player tries to search and then provides the message "No Disc" in the top left hand corner of the screen. When I put in a Blu-Ray disc it automatically finds the disc and begins to play. This DVD player used to play all DVDs in this region. I am in Canada.
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players
To ensure the satisfaction of our customers and to maintain the
integrity and quality of our products, Toshiba America Consumer
Products, L.L.C. is issuing an important product update. This is not a
safety issue.
Toshiba is committed to customer service and to continuously
improving the quality of its products. It has come to our attention
that certain DVD players bearing the model numbers SD-3980 and SD-K750
may at some point in their life stop playing discs due to a component
part failure. In such case, the error message "bad" will be shown on
the unit's display. Affected units will have "SU2" at the end of the
model name (e.g., SD-3980-SU2), which can be found on the back of the
unit.
If you own either of these models and experience the issue described
above, please contact Toshiba Customer Solutions at 1-800-631-3811 for
information on how to obtain a replacement unit.
SOURCE: Erratic operation of DVD players after a few months of non-use
what you should do is to clean the OPTICAL LENS directly with a dry Q-tip , could be that it collected some dust and thats why its playing erratically, give it a try , AJ
SOURCE: wont recognized disc
I got it work work with mine. Here's how: I removed the top cover and put in a disk to see what happens. I realized it had to be a motor problem because the dvd player was having trouble spinning the disk. I removed the part that had the motor and sprayed some air into it to clean it. It works perfectly now!!
SOURCE: Toshiba BDX2000
is there a multi region hack for the toshiba bd2000kb blue ray so i can play imported dvds and blue ray.
Pull up older posts.
You can gather all details.
Sometimes, click open the adverts' by the side and bottom of each post
might give you more details.
