Computers & Internet Logo
Anonymous Posted on Mar 20, 2012
How to upgrade quickbooks 2006 contractor to new computer windows 7
Upgrading quickbooks 2006 contractor on and xp to quickbooks 2012 contractor to an new computer using window 7 . How?
jon markan
Level 2:
Habit-Forming:
  • Intuit Expert 256 Answers
  • Posted on Aug 22, 2014
jon markan
Intuit Expert
Level 2:
Habit-Forming:
Answers
256
Questions
0
Helped
25005
Points
284
  1. From the QuickBooks Help menu, choose Update QuickBooks.
  2. Click the Overview tab and click Update Now.
  3. Select the desired downloads in the Update Now window.
  4. Click Get Updates to download your selected updates.
  5. When the Update Complete message appears, click Close.
  6. From the File menu, choose Exit.
  7. Start QuickBooks and click Yes to the message to install the update.
Note: If you experience problems with the automatic update, a manual download is available.
for more help visit QuickBooks Technical Support
5 Related Answers
Anonymous
  • Posted on Mar 20, 2009
SOURCE: Quickbooks Pro 2008 Payroll problem
Same thing here when attempting to "send payroll data", though mine's with pro 2009. I found this KB item which indicated that I should update:
http://payroll.intuit.com/support/kb/kbitem/1009052.html
I followed the update instructions here:
http://support.quickbooks.intuit.com/support/productupdates.aspx
Even though my update status was "nothing new" for each category, I hit the "Update Now" button anyway (it was enabled, why not?). It went through the motions of updating (even though there was nothing to update). When it finished, I closed and re-opened QB, then I was able to send the payroll data. This software is far from the gold standard I thought it was going to be.
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Oct 22, 2009
SOURCE: Installation Windows 7 - quickbooks will not reinstall
Is the qucikbooks 2004/2005 a upgrade or a full version ?
if its a full version right button click the setup.exe or whatever the install program is called , troubleshoot compatiblity , also try selecting the run as administrator as you may not have the right to install the program ?
Regards
GeWiz.
Anonymous
  • Posted on May 08, 2010
SOURCE: create disk fail after using windows 7
I had the same problem with ULead VisualStudio 10. I was able to press Alt-N and page forward even though the Next button wasn't visible.
Anonymous
  • Posted on Aug 12, 2010
SOURCE: I originally ran my Suretrak on Windows xp. I
Suretrak is not fully compatible with Windows 7. We have talked to Primavera on this issue and they say they will continue to support Suretrak for at least another year but have no plans to upgrade Suretrak to the Windows 7 platform.
Anonymous
  • Posted on Nov 10, 2010
SOURCE: I have the cosmi 20,000 recipies perogram in my
i think u are probably out of luck. this software looks like it came from the late 90s and will work with anything up to xp, but vista & win7 are a whole different ballgame. best solution, buy an old laptop with win98 or 2000 or xp super cheap on ebay, or beg one from a friend, and use ur software on it there in the kitchen. that's what i do with my old laptop. works great if u have room in the kitchen lol
also transfer ur fave recipes from 20,000 recipes to a recipe organizer program like mastercook, it's much much better for searching plus u can enter 1000s of new recipes from anywhere. u can get older versions of mastercook for $5 on ebay. version 8 works just great for me with winxp. (WARNING if ur interested in mastercook on ur NEW computer, get version 11, the older ones DON'T work w/Vista or win7.)
2helpful
4answers
How to uppdate from Windows Xp into Windows7 I
Well, it depends on your computer specification because every operating system has it own hardware requirements. Before upgrading to windows 7 make it sure your motherboard support the windows 7 operating system. In your case your motherboard supported by the windows 7 so when upgrading rather formatting your computer you must have the windows 7 installer. Then follow this video tutorial on how to setup your computer to windows 7. Before formatting you must have to back up all your data or files saved on your hard drive. Have a nice day
tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 • Computers & Internet
3answers
When we try upgrading xp to windows 7 the upgrading failed because our cpu is old can i upgrade my xp to windows 7 using a old cpu or use a new cpu
NO you cannot, on that same computer, no matter what OS, because, you MUST change your central Processing Unit, CPU. To allow Windows 7 to work correctly.
We purchase a new Compaq computer in September2009. We received our upgrade to windows 7. The product key is invalid and on the computer screen it says that this copy of Windows is not genuine - Build...
NO PC stated, just Compaq.
NO OS stated. xp to w7, you did not say from ?what.
this error happens if MS thinks XP is pirated.
The w7 disk words on top tell the real story,
upgrade, but is it a real MS, retail disk.
all the words on the disk tell me what it really is. post a photo?
if the PC is still original. (say HP XP unchanged)
the OS you run is from HP not MS.
that is why MS told you to call HP.
The HP software disk are custom to your PC.
unique. (windows, drivers and key HP apps)
The COA sticker on the bottom (license to use HP windows)
is a HP only license , called OEM.
that is why MS told you to ask HP.
best is to reload the OS.
if the PC was not slammed by others.
means someone put wrong OS on it. or pirated.
or new HDD swapped, or erased hdd.
then the F11 key works.
Restore F11, XP and then upgrade to W7.
Upgrages btw love to fail, its in the CARDS.
vast reasons for it, #1 is XP infections
XP has over 700 exploits, and love to fail
and upgrades as SIDE show fail.
boot the PC by power on and instantly hammer the F11 key the runs the HP Recovery off the original
HP Hard disk partition of same name.
if that is missing F11 feature.
then you have 2 choices
1: get the HP install media from HP. call them.
2; or buy a retail MS windows 7 disk. $120
see below for #2 above
its best to keep restore media on any owned
PC so when the hard drive fails, you are ready.
https://support.hp.com/us-en/document/bph07143
here is the other way, from MS
most stores sell w7-32bit home.
here is one
https://www.walmart.com/ip/Microsoft-Windows-7-Home-Premium-with-SP1-32-bit-Operating-System-PC/36009633
also at newegg
and at amazon.
this is retail disk and runs on most PC made.
after using retail disk
better is to buy a used PC with w7 on it
so you get HP support and MS support.
1helpful
Does QuickBooksPro 2005 version run with windows vista
I think Intuit draws the support line at 3 years Even though you have probably registered your product, if there is any trouble with it and the new computer, you will be on your own. I think you would be putting yourself in unnecessary jeopardy to upgrade as you describe at this time. (Your business depends on your computer and software, to operate) You must also be aware of Vista troubles.
If you are in the market for a new computer, you may opt for the new Windows 7 OS and possibly upgrade your Quickbooks at the same time for maximum benefit.
If you have the Vista computer - you already have the Quickbooks, it costs nothing to give it a try. Presumably, you have a XP computer with Quickbooks on it now ... If the Vista - Quickbooks combo doesn't work out you could upgrade the Vista to Windows 7 ... you have nothing to loose in this senerio.
I hope I have provided a little insight for you to consider.
Thanks for using fixya.com
a
1helpful
Will WIndows upgrade affect QB Basic Ed 2003?
I cant seem to find the manual for OS support. If windows XP is supported, the program works the same. For Vista and Win7 don't know really. Always when you're in doubt, makes the backup default.
I've upgraded my QP Pro Contractor 2006 to my new computer Vista 64. I do not seem to be able to upload/restore companies from 06 to 09, it just will not take the data.
2006 was not designed for operating in Vista. If the data files are not upgrading to Version 2009, it usually indicates data damage in the file. It will probably need to be rebuilt in 2006, then updated.
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
