After installing for the first time, we tried out along with the ac mechanic, immediately after switching on, the display shows "E5". It doesnt respond to any keys in the remote.
E1 : thermistor room or pipe fault
E3 : INDOOR BLOWER NO RUNNING
E5 : WIRE BETWEEN INDOOR/ OUTDOOR wrong connected or no Communication.
Indoor is quiet noisy in it its like wave sound in blower....
SOURCE: Onida split Ac displays F5/F6 error and trips
Plz check the PCB card of indoor unit,might be relay not working properly.May be dry soldring or u have to change it.It will be ok
SOURCE: onida split ac show only
That code is usually a result of a leak in the system and the unit being low on charge...find/fix the leak and recharge the unit.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air ConditionerTrouble -Review the Possibilities
heatman101
SOURCE: in our onida split ac
F2 is a fault code. im unsure what it is on your brand... Try cleaning the filters then turn the unit off at the mains supply for 15 to 30 minutes. Turn power back on and see if it restarts... If not, sorry,
