SOURCE: washer door latch
Unplug your machine, remove the top panel, doublecheck all of the
wiring is securley connected. Sometimes the wiring becomes loose due to
the machine's vibration.
SOURCE: door latch
DE error code is because there is a drain problem and it will not lock the door. You will need to clear out the obstruction in the drain pump before operating the machine. It is possible that the drain pump could be damaged from excess debris breaking the pump. In that case, the drain pump will need to be replaced.
SOURCE: LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
SOURCE: washer. door lock wont lock. I hear a click
the actual door lock switch inside the wall of your washer where the door clips in has most likely burnt out or a piece has broken out of it i have found the only way to fix this problem is to replace the door lock switch
Testimonial: " I think your right. The problem is that I can't find a new door lock without going to the manufacturer and paying too much money which I can't afford"
