When i start up my computer an error message userinit.exe appers canot load(0*80000003)
SOURCE: Problem when windows XP is starting up. Isass.exe - System Error
To work around this issue, restart your computer in Safe Mode. To restart your computer in Safe Mode, press F8 when the computer starts. Then, when the computer is in Safe Mode, add the System Pages entry to the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager\Memory ManagementTo add this registry entry, follow these steps: 1. Log on by using an account that has administrative credentials. 2. Click Start, click Run, type regedit, and then click OK. 3. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management 4. On the Edit menu, point to New, and then click DWORD value. 5. Type SystemPages, and then press ENTER. 6. On the Edit menu, click Modify. 7. Click Decimal, type 31000, and then click OK. 8. Quit Registry Editor.
SOURCE: ran a search and destroy program and it deleted system files
WoW, stay away from that program, which was it?
To correct this, you can do one of two things:
first, can you get to you desktop ok? And do you have you XP cd handy? (if you cannot get to your desktop, start with the second thing)
If the answer is yes to both questions, put your XP cd into the CDROM, then go to start >run> type in sfc /scannow in the run box. This will attempt to fix and replace the missing files.
Second thing, if the above does not work do the following:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re-installs the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: unable to login. when i
Have you installed new hardware recently? if yes, try to remove it again.
other option is to boot up using your windows xp cd, choose the rescue console, and type "chkdsk c: /f" ( without the quotes)
if that still doestn fixes it, you boot again using the cd, and then choose repair installation. let it do its thing. It will reboot when done.
