Microphone not working what can i do.....never used it before just joined skype and the receiver cannot here me, their volume is up and everything.....my mic stays red and dont know what to do now please help me, step my step instructions if poss,.....if there is a charge forget it im skint thanks
Ok My Dear , let me help you as i can.
1. right click my computer and click manage and click device manager and check if you sound hardware is properly installed . If you see a question mark that mean you have to install the driver for your sound.
this must be hard for you !!!
2. this is very easy : type fixit center in google then open microsoft fixit center website, from there you will choose your operating system , after you will choose . open this link i see how it looks like then click run
after the fixit file will be downloaded and you will run , and it will detect and fix for you
SOURCE: microphone not working
It sounds to me like your sound/audio circuitry/card is failing, especially because you mention using two different mics. There's probably a component that is getting too hot and causing the problem.
If your PC is under warranty, you might want take it in for diagnosis and repair.
But it wouldn't hurt to try another microphone just to rule the microphone out for sure.
Good luck.
SOURCE: Microphone not working, but speakers and sound is working.
hello sir
my laptop's microphone is not working but the speakers are ok.When i talk to other people on gtalk i can hear them but they can't hear me.earlier they are working but all of sudden this problem occured.plz help me
SOURCE: My microphone on my acer aspire one isnt working
in control panel, click on Sounds and Audio Devices, click on the Voice Tab, Under Voice recording, click on volume --- make sure the mute box is not checked under microphone. If it is, uncheck it. A faster way to do this is to double-click the little speaker icon in your systray in the lower right corner of your screen - right before where the time is shown. If the mute box is unchecked, make sure your mic jack is fully inserted into the correct receptacle. DID THIS HELP YOU? Please post your feedback.
SOURCE: Acer Aspire internal mic won't work.
You need to check the record settings and make sure the mic is not muted or turned down to low. Click START, CONTROL PANEL, then SOUND icon. Click the AUDIO tab up top. Make sure that your sound card is selected in the drop down menu under Sound Recording. Now click VOLUME tab. A new window will open up. Click OPTIONS then PROPERTIES. Make sure you have a check by the MIC and click OK. In the Recording Control window, turn the level up for Microphone and make sure it is not muted. Let me know what happens.
SOURCE: my dell inspiron 1525 microphone does not record.
I have a Dell Inspiron 1525. I used Skype ages ago and returned to it a couple of days ago. No one could hear me. I researched for 20 hours, downloading drivers, checking EVERY setting possible and NOW have got the ANSWER. The wires in the Microphone Array are fatigued. My microphone works perfectly when I tilt my lcd screen half way down. Go to Webcam Manager, Tools, Audio controls, the microphone has 2 bars which go green when you talk into it. Tilt your screen and watch the bars go up and down. Not the answer you probably wanted but as long as you skype with your screen half tilted everything is good to go
then
open skype go to tools from the drop down list select options scroll to audio settings also video settings you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
in the audio settings make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it
