Question about Hoover Nextra HNL 3166 Z Front Load Washer
Nextra6.will only go on 40min wash and only spin on slow spin. checked motor brushes and there fine. is it the circuit board
    Problem Solver:
  • 8 Answers
I have a hoover optima 1400AAA, it began to give trouble with programs, 40 degrees washed at 80 degrees, would not spin or empty, etc, called in a hoover repair man who cost me 120euros to remove the program knob and spray the contacts with Servisol super 10 switch cleaning lubricant, apart from the fact that I am still furious, everyone who has a hoover washing machine should know this.
Posted on Jun 01, 2012
2 Suggested Answers
6ya staff
SOURCE:
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: am 120 hoover. does not spin or slow tumble.the
If you have not already done so, check the brushes in the motor, and replace if they are less than 3 or 4mm long.
If still no go, then I would suspect the control board/programmer as being the culprit.
Posted on Jan 17, 2010
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
Aeg lavamat 66600
This could be a number of issues. Have you checked the brushes? They should be at least 15mm. Check your circuit board and make sure that the dust from the brushes did not attach itself to the board and cause a short. Use compressed air to clean the motor. Clean the circuit board with air if dirty. Check for solder joints on the circuit board to see if any cold solder joints on the relays.
Dec 17, 2017 | AEG Washing Machines
GE washer wont agitate or spin ?
This could be because the carbon brushes in your motor are worn down. One will need to check the motor to be sure.
The carbon brushes apply electricity to the motor via a split ring comutator.
Over a while the carbon dust can create a short circuit. The motor needs to be looked at and cleaned. Possibly may need to replace the brushes.
Take care!
damnor01
Apr 28, 2012 | GE Washing Machines
Hoover se147 washing machine, wont spin at all , it will fill and drain. Have checked pressure switch and appears okay. Have also had circuit board out and that seems okay.
Have you checked the carbon brushes within the motor, chances are they are worn. you will need to remove your motor to get to the 2 carbon brushes.these will be in a plastic casing, held in place by 2 screws. There is just 1 wire going to each brush. When brush is removed, the carbon should be at least 20mm long. If not replace with new
Aug 13, 2011 | Washing Machines
Bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
Jul 29, 2010 | Bosch Washing Machines
Am 120 hoover. does not spin or slow tumble.the motor is ok and has power to it. I have cleaned the printed circuit brd. connections and checked the water level switch.
Jan 17, 2010 | Hoover AL120 Front Load Washer
Slow spin not working properly
IF THIS IS A FRONT LOADER CHECK THE REAR PULLY AND BELT.I HAVE RAN INTO A COUPLE PULLYS LOOSENING UP. IF SO REPLACE THE PULLY AND BELT. ALSO CHECK THE HOLES IN THE SPIN TUB,MAYBE A NAIL IS STUCK THROUGH ONE.GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 16, 2010 | GE Washing Machines
Hotpoint Aquarius 900 WM61, washed but stopped spinning, about 6 wks ago, new brushes fitted old 1's had split everything worked fine, 6 wks down the line machine washes but doesn't spin again, bushes are...
hello carl check the module circuit board this controls the speed check the transistor on the boards for dry joints if discoloured change the board all the best
shaun
Aug 04, 2009 | Washing Machines
Motor will not start in slow agitate
I rewound electric motors in the past, in your case i don't know if its a armature motor it would have brushs. if it was if its without brushs, it would have two septrate windings one for spin, one for wash. the wash windings could be 'faulty',answer! try other motor! if you get one. let me know which motor it is Ire,Close. bye for now
Dec 02, 2007 | GE WBSE3120B Top Load Washer
Hoover Nextra HNL 3166 Z Front Load Washer Logo
409 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
