SOURCE: the cable coax male connection is disconnected from the television
The coax connector you describe is called the F connector and the silver box it is attached to is called the tuner. The original F connector or a replacement F connector can be soldered back into the tuner, but the metal frame of the tuner must be straightened out and the center pin must be delicately reattached too. This is quite an easy job but requires some labor, assuming that nothing was jammed into the tuner when the F connector was out and the coils behind the F connector have not been disturbed. I usually charge about $40 to reattach F connectors but if I have to replace the tuner I charge about $50 because it is a lot less labor to replace the tuner and they can be purchased for about $25.
SOURCE: Connection to Dish service
Your t.v is having only RFin , and if you connecting dish receiver , normaly their are two o/p for receiver one is RF and two is for audio out and video out. if your connecting direct RFout to t.v RF in then you have to tune the t.v in all bands. if your receiver do not having RFout facility, then you have to connect AV out to converter and then RFin of t.v. if you having a vcr, then connect AVout of dish receiver to vcr AVin and then vcr RFout to t.v again tune the t.v and pwer on the vcr.
SOURCE: digital to analog converter box hookup
You will have to go to Radio Shack or Wall Mart, maybe Home Depot and get a matching transformer. That will have spade terminals on one end to connect to your tv and a round (75ohm male thread) to hook to your converter box.
