The phone will not charge with the original Nokia charger or with the supplied USB lead. It used to charge with both leads, but it was hit and miss on the connection staying connected long enough for it to charge. I am worried because I can't retrieve my documents that are stored on the phone, and the battery is nearly dead. I know through experience that if you take it to a Nokia repairer they will most likely erase the data. Is there any easy way to retrieve the files, if not how do you replace the charge socket?
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
SOURCE: when connected to charger it says 'CHARGER NOT SUPPORTED'
clean the battery contact inside + battery
SOURCE: Unlocked Nokia 5310 doesn't turn on.
Maybe its your battery or charger port.Try to use another battery, if did'nt work then it's charger port.To avoid this kind of error please do not overcharged your phone.
SOURCE: Nokia E65 dead during Nokia Software Upgrade
I was just upgrading the Nokia software on my E65, connected with USB, charged and connected to charger for backup... and the phone just went dead. I've tried everything to get it going again including taking the batery out and outting it back in aain, holding the on/off button down for a minute - and nothing is happening. The screen is dead. Is Nokia's new upgrade causing this? I see two other posts to this site with the same problem in the past 24 hours. The upgrade was posted on Nokia.com 24 hours ago. my mail is [email protected]
