I have got the H20 on my machine. I have checked the inlet hose and the water flow is fine when disconnected as is the pressure. I can only think that the problem might be the inlet on the machine. I tried to look at it by removing the top. I undid the two screws but something is also holding the top from being lifted.
SOURCE: My indesit wixe 127, wont
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
SOURCE: Indesit WIXE 127 The machine is
Demo Mode
If the machine is on Demo mode 'D on' will be displayed and the machine will NOT function.
To reset the machine for normal use:ยท
Turn the power off at the wall.
Push in and hold down the Start/Stop and the Start/Reset
buttons, while still holding down, turn the machine on at the
wall.
'D off' will be displayed and the machine will function
normally.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: indestit wixe 127 is leaking water from under the
The only way you can find out where the leak is coming from is by removing the back and putting water in it. Using a torch try to see where it is leaking from. TBH its usually the door boot (the rubber seal around the inside of the door). As for the noise.... Open the door and take hold of the shiny part of the drum inside. (Just that bit). Try moving it up and down. If there is any play in it and it rocks a little that is your bearings going and can be an expensive repair. Hope that helps.
