SOURCE: shake when spins even when no clothes in it
Make sure the lags are solid to the floor. Any bit of difference will be exagerate when the washer spins. put a piece of paper under each of the front legs. While the washer is spinning try and pull the paper out. If you can pull the paper out with no problem, that leg needs adjusted to the floor more. If Ican help further, please let me know
THanks
Vic
SOURCE: washer is overfilling & leaking
Are you using front loader only detergent?(oversudsing) Overfilling is either a pressure switch, or pressure chamber is blocked(located toward underside of outer bowl approx 6 inches long) this is only in older machines with extensive cold washes.
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
SOURCE: Our speed queen top loader is not spinning. We are
either the belt is broken or the belt is already worn out.,
SOURCE: Speed Queen CTSAOAWN front loader, makes quite a
take front lower panel off.. there will be a white filter housing facing you unscrew abs /plastic clean out usually pennys /dimes quarters put back the same way you took off bingo problem solved<!-- from fixya rte -->
