Just watching T.V. and the screen went black, but I still have the sound.Ive unplugged cable connection, and power cord. Then re-plugged to see if that would help, but still same black scree, but perfect sound????
SOURCE: Black Screen, can hear sound though
hp has a free repair program for this problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01270780&lc=en&cc=us&product=1832457&dlc=en
SOURCE: Black out?!?!?
I finally got information from the repair shop. Apparently it is the upper and lower panel drive. The parts are supposedly not more than a couple hundred dollars, though I'll let you know when I get the bill. I do want to say that Hitachi was great when I called them. Even though my plasma is out of warranty by a few months, they agreed to pay for parts if I pay for labor. That just might keep me buying Hitachi products despite the issues I've had with my 2 plasmas.
SOURCE: White screen only on Sanyo DP26648
Your reported symptoms are odd in that most failures are related to the primary power supply but that takes down both audio and video.
The backlight is obviously working (white screen) but it is no longer receiving any video information and this points to a failure of the logic (or the output of the power supply that services logic) used to control pixels on the screen.
Some screens have the majority of the control ICs actually mounted on the LCD assembly and because of very close pin distances used on dense ICs, they are often not replaceable by hand since they were installed by robotics.
I would first suspect (and hope for) the logic voltage output of the power supply to be the culprit.
If any of you posters have had a repair done and received any kind of a detailed report (you should), would you be kind enough to post it back as a comment to this original message?
SOURCE: black screen
Hi katie_wood21,
About 80% of lcd tv failures are due to the backlight inverter, I suspect that is your problem.
An easy way to check it is:
If you are able to see video you have a backlight inverter failure.
If the tv is still under warranty you should begin the return or replacement process now. If no warranty you can take it to a local tv shop and pay about $250 to $350 for the repair, or you can repair it yourself.
Let me know your findings and I will assist further.
Please rate this solution, I know I didn't deliver good news but I gave you the truth without a big run around.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Vizio GV47L screen went black and is now unresponsive
Change the main board if you have good picture and sound. If you don't have picture and sound, the inverter will also need to be change.
