I was scanning photos to my computer when suddenly the colour went a strange bright yellow. now when I try to print text from the scanner the page turns a yellow /green. Please help.
    Master:
  • 569 Answers
Try getting your scanner serviced
Posted on Nov 07, 2008
6ya staff
SOURCE:
My Epson R320 prints yellow over everything
One key diagnostic you need to perform is a nozzle check. This will tell you what has happened to the other ink colours as much as indicate if yellow is polluting other nozzles.
You can run a nozzle check from Printing Preferences > Maintenance.
Once it has printed you should (normally) see a sort of stepped grid pattern similar to this.
If you can scan or take a photo of the output and the post it as a follow up it'll then be possible to get a bit more of an idea of what could be happening.
Jun 30, 2013 | Epson Stylus R320 Digital Photo Inkjet...
I have a MP280 printer/scanner/copier that prints my photos out to dark, when it is on the computer it is pefect colour
Open the printer driver setup window
Select the manual color adjustment (or if already in manual and it had initially been printing fine, you may opt to select Auto)
On the Main tab, select Manual for Color/Intensity, and click Set....
The Manual Color Adjustment dialog box opens.
Specify the brightness
Select Light, Normal, or Dark for Brightness, and click OK.
The current settings are displayed in the settings preview on the left side of the printer driver.
Complete the setup
Click OK on the Main tab.
When you execute print, the data is printed at the specified brightness.
May 16, 2012 | Canon PIXMA MP280 Photo Inkjet All-in-One...
Hi, I have Canon Pixma MP270. IS it possible to scan photo negatives and change to colour prints. thanks. Blair
A multi-purpose printer scanner cannot scan negatives or slides.
You need a slide scanner or a flatbed scanner that is capable of scanning negatives and slides. Not all flatbed scanners are capable of scanning slides and negatives.
Sep 27, 2010 | Computers & Internet
Printing only orange and yellow
Hi Florian,
if the cartridges are full, but still not all colours appear, it could be a driver issue. Try uninstalling the printer, reboot and install it again. Even pull the cartridges out and back in, just to be sure. Preferably check for newer printer drivers on Canon´s website. Let me know how it ended up Flo, ok?
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Discoloured bar on scanning from Epson Perfection 1670
It may be caused by driver conflict. Try to reinstalled OS and driver.
Jul 24, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Scanner Printing Yellow Background (Macintosh)
Same problem as above with my HP scanjet 2400.
Dec 28, 2007 | HP ScanJet 2400 Flatbed Scanner
How do I scan colored paper and still read print? HP Scanjet 8270
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
Jun 25, 2007 | HP ScanJet 8270 Flatbed Scanner
Computers & Internet Logo
Ekse
Marvin
Marvin
