HEALTHRIDER R60 SoftStrider Treadmill Logo
Thursday Posted on Mar 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Healthrirer r60 the belt just stops when using it, step off the belt it will start up till I get back on, then it stops again. what can I do to fix ?
Treadmill Repairs Brisbane
Level 2:
New Friend:
  • Expert 338 Answers
  • Posted on Nov 12, 2013
Expert
Level 2:
New Friend:
Answers
338
Questions
0
Helped
77746
Points
473
Tighten the running belt.
Get on tredmill it stops
Having the same problem, was wondering if you found an answer. I also noticed that my belt, track, whatever is out of alignment. I am wondering if it is some sort of safety thing if the track is off line.
Belt shifted to side
You need to tension the belt .
Turn the machine on and up to 4 kph or 3 mph.
Stand on the side rail with 1 foot and try and stop the belt with the other. If you can stop at all tighten the rear roller with the allen key provide with the machine. Turn it on both sides clockwise 180 deg whilst machine is still running. If still loose tighten another 90 deg.
Start R-60
see the video and proceed according. God bless you
2) LUBE the deck belt
3) LUBE the rollers bearing too
4) Test the drive belt motor
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubleshooting HELP.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram
God bless you
1helpful
I have a Healthrider R65, engine works wellbut when I step on it skips and stops for afew seconds my husband adjusted belt on each side but is till not going smoothly please adviceI bought from my fri
1) Lube the deck belt, this produce enough friction between deck vs deck belt, and shut down for to protect the electronic system
2) lube the rollers bearing very well.
3) Test the drive belt and replace
4) Test the motor input voltage, if there are the motor need repair.
5) test the output voltage board, for input voltage motor, if there are not the board is faulty.
God bless you
How do I fix a problem with the belt slipping?
hi there
it could be 2 things of this problem
1 walking belt slips easy ti fix
1th step; put treadmill in speed of 4 mph and step on side and try with one leg to stop it (be carefull) if you see walking belt stops with align key give more tension from the back of treadmill rear rollers by turning both bolts clockwise same degree with small turns till stops
if it does not help it is probably drive belt
you need give more tension on motor by using 9/16 wrenches
3helpful
Healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
I have Lenovo R60. There is a problem while loading windows xp.
There might be a minor system glitch on your system. Perform a system restore in you system and restore your computer from the date where it is working fine then observe. If same issue will occur then you need to send it to our repair department for further checking.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Baught belt - need to know how to chane it
YOU HAVE WHATS CALLED A TENSIONER PULLEY IN FRONT OF ENGINE , ONE OF TWO PULLEYS THAT ARE SLICK (NO GROOVES). THE TENSIONER PULLEY IS WHAT YOUR AFTER. IT WILL BE ATTACHED TO A SLOTTED BRACKET WITH A BOLT HEAD DIRECTLY BEHIND IT.(LOOKING AT ENGINE FROM FRONT OF VEHICLE ITS USUALLY ON YOUR FAR RIGHT!) FIRST UNLOOSEN BOLT ON FRONT OF PULLEY ABOUT FIVE TURNS , THEN MOVE TO BOLT ON TOP BEHIND PULLEY , AND START UNLOOSENING IT TILL PROPER TENSION IS RELEASED TO SLIDE BELT OVER ALL PULLEYS(USE BELT DIAGRAM UNDER HOOD FOR PROPER INSTALLATION. ONCE BELT IS ON REVERSE STEPS 1 AND 2. TIGHTEN TOP BOLT BEHIND TENSION PULLEY TILL BELT HAS ABOUT A QUARTER INCH PLAY IN IT UP AND DOWN (DON'T OVER TIGHTEN).THEN TIGHTEN FRONT PULLEY BOLT TILL VERY SNUG.YOUR DONE! BELT MAY NEED RE-TIGHTENED AFTER DRIVING A FEW DAYS , BUT YOUR AN EXPERT NOW AND THAT WON'T BE A PROBLEM. HOPE THIS HELPED!
Hoe to reboot my computer lenovo r60
go to start in the left corner below in the desktop and click it then you will get "turn off" or "shut down" click on it then you will get the option for "stand by","turn off" and "restart", just click on "restart", and you computer will reboot, if you click on turn off then the pc will shut down
dont forget to rate the solution
Top HEALTHRIDER Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
