SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
SOURCE: Jensen JER321 3-Device Universal Remote
coding:
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press
and release the ON-OFF key repeatedly until your component turns off.
Wait four seconds between each keypress. Each time you press the ON-OFF
key, the illuminated ON-OFF key blinks and the next code in the list is
sent. This process continues until all of the codes in the Code lists
have been searched. If your component turns off, you have found the
correct code.
7.Once you have found the correct code, you must save
the new code by pressing and releasing the STOP key. The illuminated
ON-OFF key turns off. You must press the STOP key to save the code or
the correct code will not be stored.
SOURCE: Emerson TV- Sentry Really Big Universal Remote
www.remotecodelist.com .........................................T.
SOURCE: GE 24912 - 3-Device Silver Universal Remote Control
http://www.jascoproducts.com/support/universal-remote-codes.asp
SOURCE: I need a universal remote code for an Emerson
You might need to get the RC65 direcTV remote control, you can find them on e-bay relatively cheap, other that that i got mine to work with the code 11864!!
