How do I change the smtp settings
SOURCE: Ricoh Aficio 1075 - SMTP error message
To use the scan to email function on your copier you need some settings from your internet provider (email setting specifically). Go into Outlook options and get your SMTP server, user name and password.
On your copier you need to change under User tools, system setting and file transfer and put these settings in. As long as your machine is set up for scan to folder thats all you should need.
SOURCE: Ricoh 1232c scan to email SSL issue
no work around for machine. you can scan to a folder on the network, than attach your doc to an email. only way to do it on a ssl.
SOURCE: How do you change SMTP server settings on the
changing settings for admin/default email account.
goto user tools
the settings are either in interface or network.
for specific users
goto user tools>admin>adress book > select the user and in there it will be in email settings.
of course this is all much easier from the web interface. just put the ip into a browser window and go from there!
