I have a SC672 error flashing. How severe is it, and what do I need to do to clear it? I just bosught the machine, the developer unit was recently replaced and the fuser unit is still in good condition. It's only done 350 000 copies. Please help me.
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
SOURCE: Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
SOURCE: Reset admin password for web-interface
If you're 'ok' with resetting all the network info such as Ip address, Etc - not to mention the scanner locations, fax speed dials etc. then you can email me. I will give you the instructions to reset "NCS" which will set all network settings to default, but I haven't got the time to walk you through all of the reconfiguration settings - - you're on your own there.
[email protected]
I don't post service mode adjusmtents here
SOURCE: Gestetner DSC224 Scanning and Fax Issues
scanrouter? disable delivery server from scanner menu
SOURCE: I HAVE PROBLEME OF GESTETNER DSC224 ERROR COPIER
Fuser oil end On the rear of the copier is a cover that is near the lower center of rear cover you need to add silicone oil (fuser oil) to the copier and cycle power. Oil P/N A2579550
-Carl, please let me know if this helps.
I am sure somebody out there can help me. Also need a Technical Manual. If you know where I can download it, leave me the URL.
