HP PSC 1610 All-In-One InkJet Printer Logo
Posted on Nov 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp printer i cant installes my hp printer 1402
Ginko
Level 3:
  • HP Master 19,396 Answers
  • Posted on Nov 11, 2008
Ginko
HP Master
Level 3:
Answers
19396
Questions
25
Helped
8076960
Points
55462
Download and install software from HP website here: » Support & Drivers
Hp 1402 fatal error and MSI.scan
Hi Ihan,
You are facing terrible problem with that error message.. However we can try to fix it. There are few methods you can do..
Solution 1.
  1. Insert the product software CD into the CD-ROM drive on the computer.
  2. Right-click Start and then click Explore . Windows Explorer opens.
  3. Locate and select the CD-ROM drive that contains the product software CD.
  4. Locate and double-click the Setup and then the Scan folders to open them.
  5. Double-click Data1.cab or Scan.cab to open the contents of that file.
Extract, rename, and save the filesLocate the following files, right-click them, select Extract , and save them to the Windows Desktop. Leave Windows Explorer open after extracting the files.
  • F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the Desktop, right-click it and rename it to TWUNK_16.EXE .
  • F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWUNK_32.EXE .
  • F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN.DLL .
  • F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN_32.DLL .
Then you have to copy these files to C:\windows\system32 folder ( this means overwrite the files ) and try to install the software. it should work.
for better understanding check the link below.
MSI.SCAN Solution
Solution 2.
you need to remove all the HP Printer entry from Add/remove or Programs and features under Control panel.
Then download the latest software from HP website by clicking on the link below.
HP PSC 1402 Printer Drivers
Regards,
Suhail
1402 Need Reflash
Alot of people are having the same problem with the hp printers i have looked at many printers with this problem and the most i have solved with reinstalling the printer to the computer you can do this by going to tcontroll panel > printers > right click and delete printer
then reinstall the printer using the disk or by clicking add new printer
im sorry but this is all the information i can provide on this problem
Hp psc 1402 all in one scanner not scanning
just chek in my computer is that show any scanner last on screen if it is then scan thru that tool if there is no scanner icon avalable then i need to set drvier thru device manager... it's help u
7helpful
2answers
HP PSC 1402 All-in-One Printer
I HAVE (HP PSC 1402 ALL IN ONE PRINTER
THERE R ONE AED IS BLINKING THIS LED IS MESSAGES IS "CHECK PRINT CARTRIDGE ERROR , BUT I N CHANGE MY PRINT CARTRIDGE PLEASE HELP ME WHATS MY PRINTER PROBLEM
3answers
Give the solution of my HP PSC 1402 All-in-One InkJet Printer Problem
Have you tried to download the driver form HP Support and install it?
And....are you using Vista?
Here is the support page for your printer.
PSC1402 Support
Download the correct driver for your operating system.
Uninstall (delete) the printer and start over. Make sure you disconnect the usb cable before you install the software. Don't plug it in until the software prompts you to.
HP 1402 All-in-one problem
four problems for sure.check out 1 by 1.
1)either the power outlet itself is faulty.
2)either the power cord wire is faulty.
3)either the adapter in which the power cord is fitted is faulty.
4)and last but the costly 1 the jack of the printer in which the power wire is inserted is faulty internally.
1helpful
4answers
Printer HP PSC 1400 to run with Vista program
You will need to go to the HP support site,
http://welcome.hp.com/country/us/en/support.html
Find your specific printer, and download the driver for Vista. Should not be a problem after that.
» HP PSC 1401 All-in-One
» HP PSC 1402 All-in-One
» HP PSC 1406 All-in-One
» HP PSC 1408 All-in-One
» HP PSC 1410 All-in-One
» HP PSC 1410v All-in-One
» HP PSC 1410xi All-in-One
» HP PSC 1417 All-in-One
k24674
Grand Canyon Tech
Grand Canyon Tech
