I lost my passwords RFS6000 , I would like to know how , what port , what soft , so use to reset and configure from scratch again paso -by-step thank yo
write in your command promt ipconfig, and find number which strat with 19*.**..... (your ip addres). That number post in google login with username: admin password: admin. And after that find password and thats it.
log in to the modem as if you were going to change the wireless password (browse to default gateway and enter username and password) then turn off SSID broadcast (usually by un-checking a box)
Log in to the modem as if you were going to change the wireless password (browse to default gateway and enter username and password) then turn off SSID broadcast (usually by un-checking a box)
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router.
If you are still not able to access it with above ip then press RESET button for 10 seconds then all settings defaults.
Then you can access it with above default ip.
Let me know if you need further assistance. Thanks for using FixYa.
It will be one of two things or both - either your computer is not
setup for DHCP or your router is using the same IP address as your ISP
or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this) a command window opens, type "ipconfig /all" without the quotes. The line with "IP address" gives you your ISP IP addr. Compare this with what you get from your router manual if they are the same then do the following:
To
configure your computer to use a DHCP IP address, go to the Control
panel => network connections => Properties (right click on your
default connection) => double click Internet protocol (From general
tab) => (a new window pops up) from the general tab ensure that
"obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following: IP Addr => 10.10.1.1 Sub net mask => 255.255.0.0 Default gateway => IP address from your ISP Make sure to the router is set to act as a DHCP server.
