SOURCE: got noise from fan told its fan on hard drive worn
The hard drive does not have a fan. There is a fan on tht CPU heatsink and a fan in the power supply. You may have a case fan for additional cooling, but this is not always installed.
Noisy fans are easy to replace, but not the one in the power supply.
SOURCE: Fan makes a lot of noise, then computer suddenly shuts down
Your computer seems to be overheating. Probably the heat sink or air path to the CPU is dirty, or you have a hardware device making interference with the air path way. You may also have bad BIOS configuration try downloading and running core temp 1.0 google it. The program will give you recommended fan speeds and will tell you the temperature of the system. If non of this works, your computer is a SIMPLY lemon.
