Question about Kenmore Elite 45986 Front Load Washer
Smelly discharge water - Kenmore Elite 45986 Front Load Washer
    New Friend:
    Problem Solver:
  • 4 Answers
Smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Posted on Apr 02, 2012
Anonymous
SOURCE:
Is this a hernia?
this is a question you need to ask of your doctor . not us on FIXYA.COM
Aug 06, 2016 | Sport & Outdoor - Others
Washer pulls in dirty water through drain hose
Hi Les,
Yes there is an easy way to resolve this.The way that a washer hose is intended to be rigged is the hose goes HIGHER than the machine itself. The reason is there is NOT a valve that keeps water from running out that hose, only the fact that the hose is routed so high.
So, this discharge hose then typically has a 180 degree bend and then about 4 to 10 inches of hose. THIS end of the hose is intended to fit LOOSELY into a plumbed drain line. Because the hose fits loosely into the drain line, that provided the required air break that prevents siphoning.
This "plumbed drain line" must have a "p" trap in it or sewer gases will fill back into the house.
Doc
Jan 20, 2014 | Washing Machines
BOSCH MAXX WFO 2062
Have you checked the outlet pipe that the machines pipe discharges into ? Sometimes these get filled up with sludge etc and may siphon back in smelly water at the end of a cycle. You could also see where the pipe drains into the sewer system , see if there is a local blockage.
Jan 08, 2014 | Washing Machines
Water from garbage disposal backing up
Check to see if there is a loop in the drain line. The drain line coming out of the disposal has to have a loop in it that is higher than the disposal. That way water can't drain back into the dishwasher.
Dec 31, 2017 | KitchenAid Dishwashers
Smelly black discharge from hot water every so often seems like a chemical reaction with well water and what heats the water in the tank. When turn off power and let the hot water sit for awhile there is...
Turn off water heater and flush it out. Hook hose up to hose bib on water heater.Close valve on hot water side.Run hose outside or into a drain.Open valve where you hooked up hose and let run 20 to 30 minutes to clear out tank.I would recommend putting a filtering system on the line going into the tank.This should clear up the problem.If not you have to have the anode rod replaced,depending on the age of the water heater.If you want to learn more about the anode rod,google anode rod ,it will bring you up to a site that will explain to you what it is. You will have to go to a plumbing supply store to find one.
May 31, 2011 | Little Giant Water Heaters
There is a terrible smell from my washer
Hi, what happens is that water sits at the bottom of the discharge pipe, as well as a build up of "gunk", which is a great breeding ground for bacteria and such. So during the first rinse out, the smelly water and gunk is discharged into the drain, and the smell comes up from the laundry tub drain. Pour a few cups of bleach into the discharge hose and let it sit for an hour. This will kill all the nasties. Then just run the machine once through to pump out the bleach.
Sep 09, 2010 | KitchenAid KHWS01PMT Front Load Washer
I have a smelly vaginal discharge
You need to wash it with 80/20% ammonia/vinegar solution. If it still persists try anti-body-otic. If very persistent, purchase MAPP Gas fuel in yellow cylinder attached to torch nozzle and incinerate until it's not visible superficially. Washing helps keep germs and viruses infecting operating parts.
May 02, 2010 | 2000 Volkswagen Beetle
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
"smelly water" from hot side of electric hwh
i always take them out. they say it voids the warrentee but i have never had any trouble with it removed.
Jun 06, 2009 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Elite 45986 Front Load Washer Logo
697 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
James Hensley
James Hensley
