Hi FixYa there's a problem with the new iPad. It gets really hot when I play a lot of games throughout the day especially if a sit down for a massive gaming sesh. Most of the time I have to end up putting a blanket down on my lap and you can forget about me wearing shorts with that thing on my lap. Does anyone have any tips on this for me? And don't say "play it less" or something like that because I didn't spend $500 to not use it.
Hi Jessica,
Much to your chagrin I bet, there's not too many options besides "play it less" if you want to cool your new iPad down. If the heat is an issue for you now it is probably going to continue to be an issue for you later.
Having said that, there are a couple ways I have used that seems to cool down the iPad by a few degrees:
I hope that helps you out!
SOURCE: How to play 1080p mkv videos on the new iPad
Well, the new iPad only supports to playback videos in MP4, MOV, M4V format. So, if want to watch 1080p MKV videos on the new iPad in 1080p, you need to convert the 1080p MKV to 1080p MP4 format first. From Google search comes this following guide shows you how to convert 1080p MKV video to 1080p MP4 for the new iPad.
Read this "Turn 1080p MKV to 1080p MP4 for The New iPad"
SOURCE: I was using my Ipad playing games and the screen
It's a rare but known issue. A trip to the Apple store is in your future, I'm sorry to say.
SOURCE: where is the ipad mute button cant get any sound
The mute switch is on the right side of the iPad. Check your switch settings first:
Tap Settings > General.
Under "Use Side Switch to:", select Lock Rotation or Mute.
Settings > General
Make sure you're using it to mute, and then slide the switch to toggle mute on and off. Also use the volume rocker in case you have the volume set too low.
I can't start a new game and no one is playing in games already started
