I have a large rear projection tv -jvc HD-Z70RF7 , There is a large shadow covering most of the screen making it hard to see picture , we also get spider webs that we can see that are on the inside of the tv... this very enoying PLEASE how can we fix this problem ? Thank you Tracey.
SOURCE: Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
SOURCE: Sony KP-61HS10 Rear projection TV blurry /shadows at first start
Sounds like the convergence ic's need to be replaced or resoldered. Sometimes it can be a microfuse if you are lucky. But my question is if you hit the focus button up front does it make it thru the auto convergence? Let me know. Have a good one.
SOURCE: Dark Blotch on rear projection TV screen
usually these are caused by cleaning the screen with a damp cloth or fkuid rear projection tv's usually have two plastic screens separated by about quarter inch with bulbs between,one being a magnified screen.problem is,condensation can occur causing various blotches,letting the screens naturly dry out usually solves this but failing this you have to strip down and wipe them with clean dry cloth.be careful though the inside screen is very delicate.
SOURCE: Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
SOURCE: JVC HD-56G886 56INCH REAR PROJECTION TV
I REMOVED THE SIDE DOOR OF MY JVC AND SAW THE LENSE HAD DUST ON IT. THE HOLE IS KIND OF SMALL SO MY ARM DIDN'T REACH THROUGH ALL THE WAY TO GET TO THE LENSE AND CLEAN IT. MY WIFE HAD A SWIFTER DUSTER (YOU CAN FIND THEM IN THE CLEANING ISLE OF MOST SUPERMARKETS)SO I TRIED THAT, WORKED GREAT!!! CLEAN PICTURE.THANKS CASTINE AND CINDERBELLE.
