Honda 6370C - Parallel Power Kit For  EU3000i Logo
Posted on Nov 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power output from a generac c5000 generator
I'm a seasoned veteran with automotive electronics but am afraid I lack the knowledge to effectively troubleshoot a no power problem on my old portable generator. Any tips would be appreciated
  • 2 more comments
  • StoneCoast Nov 29, 2008
    Engine runs at the proper RPM but no 120vac output on any legs. Breaker isn't tripped.
    Generac C-5000
    Model 09397-0
    Series C5032
    Serial # 1315716
    Techumseh engine
    Model HM100-159252L
    B3291A
  • sawoodmansee Dec 22, 2008
    I have a Generac model 09856-0 that runs fine but has no current output.The brushes appear to be almost new. I checked for burnt wires on the armature, and cleaned the brush rings w/ 400 grit sandpaper. Re-assembled the whole thing no change. Also tried to excite the field w/12v d.c., it didn't help. I did desolder two of the diodes to check them. Hope they were put back in the right direction. I guess what I'm looking for is a step by step troubleshooting guide for portable generators in general. I also have a smaller Honda with a similar problem.
  • Anonymous Mar 16, 2014
    I have a Wacker portable generator G3.7. It has been sitting for 4 years and when I started it up this winter, it will not generate any power. Where may I download a repair manual?
  • Anonymous Mar 17, 2014
    5.5kva generator constantly revving very high even when nothing is plugged in.
Randall Goldsmith
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 11 Answers
  • Posted on Nov 16, 2016
Randall Goldsmith
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
11
Questions
Helped
8677
Points
30
This gen-set may have lost its magnetism, to restore it, get a plug in drill, plug it into the generator, start the gen, pull the trigger on the drill and turn the chuck back and forth as fast as you can a few times, please wear gloves, wait a little and try it again, if it starts to work,, problem solved, maybe, so shut it off and try it again, if it works without the drill being spun, great, if you have to do the drill again to get it going, you have other problems, a Generac I have has a little electronic device that goes out, it was cheap, but I am pulling my hair to remember what it was called,, . when it was out I had to use the drill every time to get it going, not fun!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5182
Points
I have a generac generator 5000 power+5, model 9856-0. I am trying to order carburetor parts for a the briggs & stretton 10 hp engine. I can not read/see the model number on the engine plate. I was wondering if anyone knows the engine model number fro this generator . thanks
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Feb 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
36632
Points
5
Refit the brush pack, check the exite cct resistance throught wiring down through the brushes and back from a connector further up the loom preferrably righ up at the control section.
Gernally this should be under 100 ohms.
Previously I have reduced from 260ohms  to  75Ohms  and this was enough to move the machine from totally dead to working to spec.  Steve
Anonymous
Level 2:
  • Expert 169 Answers
  • Posted on Dec 03, 2008
Anonymous
Expert
Level 2:
Answers
169
Questions
Helped
234174
Points
413
First check the circuit breakers on the control/outlet panel.
Then take the end off the generator and look at the brushes (usually what breaks) and the 2 slip rings they ride on (these get dirty and have to be cleaned off with a bit of emery cloth)
Then look at the voltage regulator (the little board that the brushes plug into)
Let me know if you need more detailed help,
Carl
I need a owners manual
Owner's Manual - Northern Tool + Equipment
www.northerntool.com/.../manuals/166114.p...
Northern Tool + EquipmentOtherwise, back feed from the generator into the power grid could kill utility workers...... information, always refer to the engine Owner's Manual furnished with thegenerator. .... (a) Hard-starting motors require 3-5 times the rated running watts.
Online Product Support - Generac Power Systems, Inc.
www.generac.com/.../product-support-lookup
Generac Power SystemsOr how about a new hose for your pressure washer? Shop and buy genuine Generacparts and accessories for your home backup generator, portable generator ...
[PDF]Owner's Manual - Home Depot
www.homedepot.com/.../66508163-2ff4-4048-9162-0...
The Home DepotThis manual contains important information that you need to know and understand in ...Power Output. This generator is not designed to power sensitive electronic equipment... Do not touch electrically energized parts of the generator and.
[PDF]Owner's Manual - Smarter Tools
Generator runs,no power at breakers or output plug,has been started and shutdown under load. 5.7 volts on wires coming from stator. All three wires.this is on a motor home.
have the unit checked by an authorized generator repair shop
if it was operating when shore power came back on there is every possibility that the generator or inverter has been damaged from the lack of synchronization of the sine wave
Why isn't it producing rated output?
Rated output is at full load. Units will produce power up to that limit and use gas accordingly. Very lite load = less output and less gas consumption, etc.
Where is compression release
If you can get it running, run some "Sea Foam" cleaner through it. Sounds like the valves (reed) are gummed up... I don't think there is a compression release on this machine, but you can get the manural at: Generac Power Systems The best backup generator for your home business...
My generac rv generator runs bu no voltage output.
Try putting 12 volts across the commutator at the brushes. Ust a low current battery nor a car storage battery.
Good luck,
Marty
Installed a generac 20kw about a year ago, ran fine untill 2 days ago. During a utility outage, generator ran for about 30 minutes and then stopped producing power while still running. All mains were still...
With the engine off, check the exciter brushes and slip rings which supply magnetic power for the alternator winding in the stator. Also, check the motor-to-alternator mechanical coupling. Check the breakers for tripping. To service beyond this point requires a schematic of the alternator, a voltmeter, plus knowledge of what the schematic is telling you. Good luck!
Top Honda Electrical Supplies Experts
vince
Paul Carew
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
