The washer just stopped one day, with the F50 code flashing, not letting the washer go past the first minute of wash.
I also had an F50 code on my Cabrio top load washer. Went through all the diagnostics, removed the tub, checked the motor, etc. After a lot of research, purchased a new control board (part #W10189966) and....it works even better than before....no more noise and spins perfectly. Very easy to install (3 screws and one bolt.) Please don't waste your time (like we did) checking all these other areas of the machine. The part was $155. (google it for best price new) and worth it if it will last another year or more...
I have the same problem with my Whirlpool Cabrio. This morning it flashed F50 and now it won't
spin. Called Whirlpool and they say the code refers to an electrical
issue and that's all they said. Obviously there is an issue with this
washer that many others have experienced. Whirlpool should look into
this and consider it a recall issue.
Mike B.
I have the same problem. This morning it flashed F50 and now it won't spin. Called Whirlpool and they say the code refers to an electrical issue and that's all they said. Obviously there is an issue with this washer that many others have experienced. Whirlpool should look into this and consider it a recall issue.
Mike B.
It would seem they did not know what a code f 50 was when I called them 3 days ago they just said I shouls call a service man. same symtoms as others wont run and flashes F 50
same problem. Can't get tub to spin
I have the same problem. I have a repairman coming out in 2 days. I will let you know what he says.
whirlpool error f50
I got the same prob, now f50 and f51 when analysis is done, no spin. I replaced the RPS and wiring harness today and no luck. The motor tests ok at 32 ohms resistance. I dont know what next? Possible main circuit board???
same F 50 fault with cabrio washer how do I find out what needs to be fixed
