I have error e000020-023 on a canon copier irc 3080i when i replace a new drum unit. But if i put the old drum i don't have the error code. please very urgent. thank you.
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
SOURCE: canon irc 3200 error code E000001-004
Want to print a Microsoft Office Publisher document to Canon iR C3200 and it gives'
me this message: Cannot continue to print as the disk is full. I have plenty of room on
my drive and so does the copier. Please advise
SOURCE: sharp ar 5320 error code f2
i have practised the same error before after replacing a new toner cart. we noted that there a slight difference bet ween versions of cartridges , pls note that on the rear side of the toner cartridge there is a plug in sensor tied with 2 screws . tyr to replace it with the one on the previous cart. i did that before twice and it will do . the f2 disappears . pls try the same and if lucky, let me know, with best regards
SOURCE: canon IRC3100 colour copier machine error code
This is what this machine does best! :P
Since you have already had the drum out, pull it out again. get a small flash light and look inside. About half way inside, at about the 10 or11 o'clock position is a small sensor that shines on the drum. Take a cloth and wipe the surface and reassemble and all should be well. Note the colour of the toner wiped off the sensor, (it is most likely black) if the problem returns then the developer unit of that colour needs to be replaced. The black can be replaced by itself but the colours should be replaced as a set.
SOURCE: Average useful life of Sharp AL-1661CS
With that machine the toner cartridge also contains developer. Without getting too in depth, it sounds like maybe your toner cartridge is leaking a bit of developer which takes with it a bit of toner. Developer is made up of tiny metal particles which are supposed to stay inside the developer unit. As the seals wear in the developer unit (which is part of the cartridge) it allows a little to leak out causing the problems you are seeing.
When you take the toner cart. out, at the rear side (part that goes the furthest into the machine) you'll see a white foam seal. If you notice some excess toner (and probably developer) sticking straight out from that, it could be that the seal has a jagged edge which is dragging developer off of the magnetic roller and depositing it on the drum making the line you speak of on the left hand side.
Also check to make sure the copier is sitting level, if it's not then the concentration of toner at one end of the developer unit is too great and some can be allowed to spill out.
So in short, it's probably not the drum that's at fault, it's more likely the toner cartridge.
Is it worth replacing? There's no easy way to answer that. If the machine is used in a fairly high volume workplace, it's probably worth replacing. If you could get by with a smaller cheaper machine (brother, HP, lexmark etc.) that does printing, scanning, faxing and copying you may be better off.
have the same problem this morning....
