Sewing Machines Logo
Anonymous Posted on Mar 28, 2012
What does a 77 error code on a Bernina sewing machine mean?
77 error code
  • Anonymous Mar 28, 2012
    What is an error 76 or 78. It does not go away by turning the machine on and off. The only thing I can do is to turn the machine off and tap the feed dog lowering button while I turn it back on. Is there a sensor that should be replaced for the feed dog?
Anonymous
Level 2:
New Friend:
  • Expert 34 Answers
  • Posted on Mar 28, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
34
Questions
Helped
11026
Points
104
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
4 Related Answers
Mimito7
Kelley Buchanan
  • 130 Answers
  • Posted on Apr 30, 2009
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Anonymous
  • 619 Answers
  • Posted on Feb 22, 2008
SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
RickE1
Rick
  • 202 Answers
  • Posted on Oct 08, 2009
SOURCE: I have bernina sport 801 machine and need to know
You can oil any two metal parts that move togeather or through each other. Do not oil bearings and do not oil gears. Do not use 3 in 1 oil or WD-40. Use regular sewing machine oil.
801's were made from 1979 - 1982. The way Bernina dated these on the machine is by the serial number. Your number would probably start with a 0 or a 1. 1970 is a 0, 1971 is 01, 1980 is 1, 1981 is 11, 1990 is 2, 1991 is 21 etc. etc.
Rick
Anonymous
  • Posted on Nov 11, 2009
SOURCE: Bernina Bernette 65 sewing machine
I had the same problem. I'm a novice sewer. I just bought my machine. It did the samething, tension didn't work, the thread kept knotting up underneath, and the fabric kept curling up in the back.
I adjusted the tension knobs to no avail. Then it kept bothering me that it was curling up. I then decided to set the dials back to where the factory had them and adjusted the presser foot just a hair counterclockwise and I haven't had anymore problems.
The other day the needle almost broke because the tension was tight on the thread. You have to make sure that the needle is at it's highest point to get it to release the fabric so you have a thread tail.
This is my first purchased machine. I had a New Home years ago that was given to me, however it blew away in the tornado of 1991 in Kansas and I never replaced it. I really do love this machine. I don't believe I will ever want another.
2answers
What does message mean? *** EvError SeverityError FacilityAnsMCU_MotorCurrent ErrorCurrentTooHigh 'main motor current was to high'.
The machine is binding and the extra power needed to turn the mechanics caused the motor to strain. The machine needs cleaning lubricating and timing.
Change light bulb bernina 880
You posted to Cars and Truck and you wrote 'berina'. Let's assume you mean a 'Bernina' Sewing machine because Holden Barina don't make an 880.
Question moved to Bernina Sewing Machines category.
Please always include FULL 'make model (what it is)', and spell check before dropping it into the right category. I deleted your duplicate. You have to refresh the page to see your question published.
There is help in the link, and access to the Bernina website.
https://www.google.com/search?q=bernina+880+change+light+bulb
Any further questions, click Comment under here.
Where i can buy motor drive sewing bernina 830 machine
If you mean the drive motor assembly than go to Sewing Parts on Line (see link )
What does hi, 'upper thread inserted' mean?
Try contacting your Bernina dealer. They should know what that error message means.
After cleaning the bobbin sensor, error message keeps coming on. What else should I do?
You should probably take it to a Bernina repair person.
https://www.youtube.com/watch?v=RHYwvv8lJ74
http://sewsabina.com/blog/?p=84
http://freemo.com/bernina-artista-730e/
2answers
Where can I get power cord, foot pedal, and manual?
About 17,700 results (0.94 seconds) Search Results
    Bernette Sewing Machines - BERNINA Support: Machine ...
    www.bernina.com/...Manuals/bernette-manuals/Bernette-Sewing-Machin...
    Bernette Sewing Machines Within this section are the Bernette series of sewing machine manuals that are no longer ... bernette 50 / 60 / 70 / 75 Manual (7.4 MB).Missing: power
    [PDF]Manual - Bernina
    www.bernina.com/de/.../BERNINA.../bernette.../Manuals/deco340_EN_...
    Congratulations on your decision to buy the bernette Deco 340. By owning .... Insert the power supply plug into the wall outlet and turn the power switch on. 1.
    BERNINA Support: Machine and Accessories Finders, and ...
    www.bernina.com/en-US/Support-US
    Out of Print Manuals. Out of ... BERNINA FAQ - Find answers to frequently asked questions. ... Please note: this service can only address SOFTWARE questions.
    www.bernina.com/.../BERNINA.../BERNINA.../Manuals/0333017104_2...
    You've decided on BERNINA, a reliable choice that will delight you for years to come. For over 100 .... Power cable. · .... control the sewing speed by pressing the foot
I would like to hear about other owners of the 880 and what problems they have had.
Go to Yahoo Groups and search for Bernina 880. The Bernina users would be the best place to get answers about problems and suggestions of what to do.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
