Washer will fill with water, make a few turns to the left and right, then shuts of with the le error code. These are rather strained turns I think and it wouldn't turn at all if there were clothes in it. After each turn there is a kind of buzzing sound that sounds kind of like 2 metal rings spinning past each other at high speed, coming from the area of the motor or bearings in the back. I can spin the drum freely by hand in either direction. This problem came on suddenly, with one load of clothes.
SOURCE: LG Tromm WM2277HW will not spin both directions, LE error.
Short answer: The post+images by “chem-prof” on Jan 10, 2008 and the post with part instruction by “wolfster” on Dec 04, 2007 solved the problem!!! You guys are the best!!!
Long answer: We purchased the LG WM2277HW three and a half years ago. We have been VERY happy with the results. Last Thursday we got the LE error code after placing a single sofa cover in for a quick cycle. I’m not sure if this is what caused the part to go bad or it’s just the fact that this part might have a “time limit” so LG can make more money on service… (sounds like my Volvo!!!). Anyways, after freaking out for five very long minutes, I Googled the phrase “LG Tromm WM2277HW will not spin” and got directly to this page (WAHOO, FixYa.com!!! You guys are great too!!!). Read the instructions posted by “chem-prof” and “wolfster”. Following “wolfster” I went to download the user manual and exploded diagram from http://136.166.4.200/contents/Laundry/WM2277.htm, then I went to http://www.mcminone.com/ and typed “P/N 6501KW2002A” in the search. Got the “sensor assembly” part for $17.50 + $22.50 (2nd day air UPS). Make sure to note “Please send me a UPS tracking info” in the comments field. Got the UPS tracing e-mail from mcminone.com and waited…. Tuesday was my delivery day (Ohio to Florida). On 5pm got the part by UPS. At 5:15pm it was all assembled and first cycle was started to run!!! Now it’s my 3rd cycle and the baby LG WM2277HW is spinning like usual!!!
OK, now let me tell you, the images by chem-prof are great, but I found that if you take the three screws that attach the electric cords to the drambase it will actually make your life easier and it you will not need to disconnect one of the cords/plug, only the small one that attaches to the “sensor assembly”. See my image for the process:
A. Take off the 4 screws for the metal covering
B. Take center large screw (#2 on my list, it was a mistake…), this will not be as easy unless you have someone else to hold the dram from the front… but it’s doable after all, I did it!
C. Take off the magnets covering, this may require some shifting left and right, while pulling to the back (placing it back is not that easy, indeed watch your fingers when placing it back!)
D. Disconnect the cords attachment screws (#1 on my list)
E. Take the 6 screws of the motor (looks like a circle with orange cords around it!) (#3) and place the motor on a towel on the floor
F. Take off the plastic part (“sensor assembly”) from the motor
G. Place the new plastic part (“sensor assembly”) on the motor
-- Redo steps E to A backwards… voualla! You’re done!
H. Take your wife and the kids to a fancy restaurant for all the $$$ you saved!
SOURCE: When to know if the motor is going out ?
well here is how i fixed my lg LE error.
i just replaced the main pcu and all better now. it was not the hall sensor nore the rotor on the motor or the bearing or even the power soap
it was the main computer. for about 170 bucks and took about 5 min to change out it was all done and wroking fine
SOURCE: LE ERROR CODE ON LG WM-2277HW
It worked!!!!!!!!!!!!!!!This is the second time it happened to me and I had a repair man come out the first time. You need to have a shop vac with you so you can just pull the plug.
SOURCE: WM1832CW, wont drain and spin,
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
SOURCE: Spinning Motor is overloading
Hi
Thanks for using FixYa. LE error is a communication error
between the control board and the motor. In you LG washer the Hall Effect
sensor board monitors the direction and speed of the motor and sends this
information to the control board. Usually the issue is with this Hall Effect
sensor going bad and should be replaced. However, to make sure it’s not a
locked motor, try turning the drum with your hand. And, if you feel some
resistance while turning the drum or the drum doesn’t move freely then the
motor is locked and you’ll need to get it replaced. If it is fine then it is
the Sensor. Please do rate the solution if the issue is
resolved or post a comment for further assistance.
Thanks
Rylee
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
