My tv is making a popping sound.
SOURCE: i have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Testimonial: "i just hope this works"
SOURCE: sony 42 in. lcd projection tv went out; just makes a sound.
The TV should "blink" a number of times after it fails to start up (the red light blinks a certain number, pauses, blinks a certain number, pauses, etc.). This tell what is wrong with the TV. If the LAMP light is what is blinking, then the lamp needs to be replaced.
Most of the problems with this television are related to the lamp or lamp chamber. If the Television lamp is burned out or worn, or the lamp will not start, then it will not try to come on. There are circumstances where the LAMP light on the front of the TV will not come on, even though the lamp is out. I would try replacing the lamp (which is meant to be user-replaceable). The popping noise you heard could have been the lamp going out.
The lamp chamber door also activates a switch that tells the TV that the door is in place. This switch will sometimes go bad, showing a relatively small amount of resistance, but enough to fool the TV into thinking that the door has not been replaced, causing the TV to shutdown. Make sure that the lamp door is properly replaced if you do remove it. It is no longer available from Sony (too many warped doors from heat damage).
Lamp part number is available in the user manual, as well as instruction on changing it.
Hope this helps you...
The loud pop was a capacitor blowing.
The light is flashing because either power board or ballast board is faulty.
Using the TV in this conditions can cause further damage.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
SOURCE: I have a sony trinitron
The Standby light LED flashing at the front panel of the TV is the self diagnostic display which can be easily identified by a service technician by counting the number of blinks.
If the issue persists after the possible troubleshooting, get it serviced at a Sony authorized service center. Check if the nearest service center is offering a Home Service.
Good Luck
KenSolutions
SOURCE: I purchased a 46" Sony Bravia flat screen TV. I
Try going into menu input set up on tv and switch to av input. Just a thought I have the same model and had exact problem. All I had to do was change input style to av cable.
