The caption option is greyed out. How do I turn it on?
SOURCE: closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
SOURCE: Closed Caption Option
CHeck on the comcast box- you may have to turn off (POWER) then click (SELECT)select button to get into the user interface , there you may see that closed catptioning is off, turn it on and it should work.
SOURCE: Model: LG 42LC7D
If your using the RGB inputs or A/V inputs I do believe that feature is disabled. You have to use the closed caption capabilities with the cable box or satellite from with-in them, which ever you may have. The CC is only active in the menu when cable is directly connected to the RF jack for input on the TV, which can be the cable box also. Hope this helped.
SOURCE: I can't get rid of the captions on the 50 inch LG TV
My Lg was doing the same thing. Every movie we watched had subtitles running at the bottom of the screen. The button was at the bottom of the remote. Once we pressed it, it came up on the screen saying CC/OFF. Also had this happen on same TV with DVD player and had to turn it off with the DVD remote. Subtitles OFF/ON
SOURCE: I just bought an LG LD450 42" tv and the closed
Hi, my name is John. Welcome to FixYa. Once you get to where it is greyed, press the + button. Thanks for choosing FixYa....John
