Presently own desk top. cannot figure out how to load pictures from my digital camera on to computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
SOURCE: how do I increase the dpi on TZ5
Hi - When talking about resolution in digital photography there are two main meanings.
One is the "pixel count resolution" and the other "embedded resolution". So for example your camera could record 2272*1704 as the actual pixel count resolution and set 72 as the embedded resolution that tells other software (for example photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it in your software to 300 for printing. In Photoshop you can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions".
So for your camera the embedded resolution is 180 which you can only change in your PC software.
This is a complex subject, I recommend looking at the following web page:
http://www.fotofinish.com/resources/centers/photo/resolution.htm
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: user manual
You can go to the link below. then scroll down to the lower portion there you will see a number of units in your device line. Select the appropriate then on the next page you can download the instructino manual
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras.list.75480
SOURCE: Camera in japanese language i want in english LUMIX DMC TZ5
Select menu
Select spanner(wrench) for setup menu.
Scroll down through the menu, there are five pages of menu items on my camera! it moves to a new page when you move off the bottom.
The language option is the penultimate item - it has an icon of a head with a speech bubble.
SOURCE: My Panasonic DMC-TZ5 will no longer focus,
If you mention "ticking clock" sounds, then most probably something like a grain of sand fell into the cogs in the zoom mechanism (been taking pictures on a beach? ;). Dirt gets into the mechanism through the gaps between the zoom barrels and the camera body. One tiny grain of sand is enough to cause the lens mechanism to jam or malfunction.
Unfortunately, this is a problem with pretty much all compact zoom cameras. Usually there is not much you can do with this. First thing I try in cases like these is gently tapping the camera to shift whatever might be blocking the mechanism. If unsuccessul, then only way I know to fix this is completely stripping the lens to clean it or swapping the lens with one taken from another camera ("donors" available on ebay ;).
If you are not keen on tinkering with your camera I would suggest selling it on ebay - TZ5 with lens mechanism issues still fetch pretty good prices.
From repairman's point of view I can say that TZ5 / TZ3 (same lens design) are much better in in terms of "resisting dirt" than various other manufacturers. They are very well made and relatively easy to dismantle and fix. This is most probably the reason why even broken ones still sell quite well on ebay.
Of course, you might get unlucky with most robust piece of kit :(
Well, hope this helps.
Good luck with your TZ5.
Raf
Testimonial: "Fairly complete response. Wish there were other solutions beside dismantling camera...8-(. Thanks anyway."
SOURCE: Problem with Panasonic DMC-TZ5, can not take pictures with Flash.
My TZ5 has developed exactly the same problem. I took it to DK Audio Services at Horley,Surrey,RH8 9GA. who repair cameras for Panasonic and was told by the receptionist that although the camera works with the flash off at present it will eventually pack up altogether. She suggested that when I get the quote I phone Panasonic on 08705 3577 357 to try and get them to pay for the repair, it seems it is a known problem! My camera is just over a year old!!
Testimonial: "Thanks, for your comment. Its good to know I´m not the only having this problem with the camera."
